[petsc-dev] PetscSF in Fortran
Jed Brown jed at jedbrown.org
Thu Oct 19 22:29:45 CDT 2017
Adrian Croucher <a.croucher at auckland.ac.nz> writes:
> hi
> On 19/10/17 06:45, Matthew Knepley wrote:
>> On Tue, Oct 17, 2017 at 11:35 PM, Adrian Croucher
>> <a.croucher at auckland.ac.nz <mailto:a.croucher at auckland.ac.nz>> wrote:
>>     So, now I'm trying to add Fortran bindings for PetscSFBcastBegin()
>>     and PetscSFBcastEnd().
>>     From the C side I have added the following into
>>     src/vec/is/sf/interface/f90-custom/zsff90.c:
>>     PETSC_EXTERN void PETSC_STDCALL petscsfbcastbegin_(PetscSF *sf,
>>     MPI_Datatype *unit, F90Array1d *rptr, F90Array1d *lptr , int *ierr
>>     PETSC_F90_2PTR_PROTO(rptrd) PETSC_F90_2PTR_PROTO(lptrd))
>>       PetscDataType ptype;
>>       const void* rootdata;
>>       void* leafdata;
>>       *ierr = PetscMPIDataTypeToPetscDataType(*unit, &ptype);if
>>     (*ierr) return;
>>       *ierr = F90Array1dAccess(rptr, ptype, (void**) &rootdata
>>     PETSC_F90_2PTR_PARAM(rptrd));if (*ierr) return;
>>       *ierr = F90Array1dAccess(lptr, ptype, (void**) &leafdata
>>     PETSC_F90_2PTR_PARAM(lptrd));if (*ierr) return;
>>       *ierr = PetscSFBcastBegin(*sf, *unit, rootdata, leafdata);
>>     and similarly for petscsfbcastend_(). Does this look plausible?
>>     Then some wrappers need to be added to
>>     src/vec/f90-mod/petscis.h90. I am not sure how to do those.
>>     The difficulty is in declaring the arrays that are passed in,
>>     which can be of various types. In C they are declared as void*,
>>     but I'm not sure what to do with that in Fortran. I can't seem to
>>     find any other example wrappers in PETSc to model it on either.
>>     Any suggestions?
> I think this is working now by just declaring those void* C variables as
> type(*) in the Fortran interface, e.g.:
>        Interface
>           Subroutine PetscSFBcastBegin(sf,unit,rarray,
>       &       larray,ierr)
>             use petscisdef
>             PetscSF :: sf
>             PetscInt :: unit
>             type(*) :: rarray(:)
>             type(*) :: larray(:)
>             PetscErrorCode :: ierr
>           End Subroutine PetscSFBcastBegin
>        End Interface
> The only difficulty I have left with this is in the MPI_Datatype
> variable. I'd forgotten that these datatypes are all different in C and
> Fortran as well.
> I amended the C interface code to the following, to convert the Fortran
> MPI datatype (actually an integer) to a C MPI_Datatype:
> PETSC_EXTERN void PETSC_STDCALL petscsfbcastbegin_(PetscSF *sf, MPI_Fint
>    PetscDataType pdtype;
>    MPI_Datatype dtype;
>    void* leafdata;
>    dtype = MPI_Type_f2c(*unit);
>    *ierr = PetscMPIDataTypeToPetscDataType(dtype, &pdtype);if (*ierr)
> return;
>    *ierr = F90Array1dAccess(rptr, pdtype, (void**) &rootdata
>    *ierr = F90Array1dAccess(lptr, pdtype, (void**) &leafdata
>    *ierr = PetscSFBcastBegin(*sf, dtype, rootdata, leafdata);
> The problem is this only seems to work if I declare the datatype in the
> calling Fortran code to be of the appropriate C MPI datatype, e.g.
> MPI_INT, rather than the corresponding Fortran datatype, e.g.
> MPI_INTEGER (which causes PetscMPIDataTypeToPetscDataType() to fail, as
> something weird gets passed in for dtype).
> I was expecting the opposite to be true. It doesn't seem right to have
> to use the C datatypes in Fortran code (confusing if the Fortran
> datatypes are used elsewhere). So I suspect I've messed something up.
> Anyone have any ideas?
I think PetscMPIDataTypeToPetscDataType should be extended to handle the
Fortran types.
BTW, this code looks very wrong to me:
  if (mtype == MPIU_INT)             *ptype = PETSC_INT;
  else if (mtype == MPI_INT)         *ptype = PETSC_INT;
  else if (mtype == MPI_LONG)        *ptype = PETSC_LONG;
If PetscInt is 64-bit then MPI_INT (which corresponds to int) would be
mapped to a 64-bit int.  Those PETSc datatypes either need to be
abandoned (I think MPI types would do) or we need a terminology to
distinguish PetscInt from int.
