[petsc-dev] PetscSF in Fortran
Adrian Croucher
a.croucher at auckland.ac.nz
Thu Oct 19 20:59:52 CDT 2017
hi
On 19/10/17 06:45, Matthew Knepley wrote:
> On Tue, Oct 17, 2017 at 11:35 PM, Adrian Croucher
> <a.croucher at auckland.ac.nz <mailto:a.croucher at auckland.ac.nz>> wrote:
> So, now I'm trying to add Fortran bindings for PetscSFBcastBegin()
> and PetscSFBcastEnd().
> From the C side I have added the following into
> src/vec/is/sf/interface/f90-custom/zsff90.c:
> PETSC_EXTERN void PETSC_STDCALL petscsfbcastbegin_(PetscSF *sf,
> MPI_Datatype *unit, F90Array1d *rptr, F90Array1d *lptr , int *ierr
> PETSC_F90_2PTR_PROTO(rptrd) PETSC_F90_2PTR_PROTO(lptrd))
> PetscDataType ptype;
> const void* rootdata;
> void* leafdata;
> *ierr = PetscMPIDataTypeToPetscDataType(*unit, &ptype);if
> (*ierr) return;
> *ierr = F90Array1dAccess(rptr, ptype, (void**) &rootdata
> PETSC_F90_2PTR_PARAM(rptrd));if (*ierr) return;
> *ierr = F90Array1dAccess(lptr, ptype, (void**) &leafdata
> PETSC_F90_2PTR_PARAM(lptrd));if (*ierr) return;
> *ierr = PetscSFBcastBegin(*sf, *unit, rootdata, leafdata);
> and similarly for petscsfbcastend_(). Does this look plausible?
> Then some wrappers need to be added to
> src/vec/f90-mod/petscis.h90. I am not sure how to do those.
> The difficulty is in declaring the arrays that are passed in,
> which can be of various types. In C they are declared as void*,
> but I'm not sure what to do with that in Fortran. I can't seem to
> find any other example wrappers in PETSc to model it on either.
> Any suggestions?
I think this is working now by just declaring those void* C variables as
type(*) in the Fortran interface, e.g.:
Interface
Subroutine PetscSFBcastBegin(sf,unit,rarray,
& larray,ierr)
use petscisdef
PetscSF :: sf
PetscInt :: unit
type(*) :: rarray(:)
type(*) :: larray(:)
PetscErrorCode :: ierr
End Subroutine PetscSFBcastBegin
End Interface
The only difficulty I have left with this is in the MPI_Datatype
variable. I'd forgotten that these datatypes are all different in C and
Fortran as well.
I amended the C interface code to the following, to convert the Fortran
MPI datatype (actually an integer) to a C MPI_Datatype:
PETSC_EXTERN void PETSC_STDCALL petscsfbcastbegin_(PetscSF *sf, MPI_Fint
PetscDataType pdtype;
MPI_Datatype dtype;
void* leafdata;
dtype = MPI_Type_f2c(*unit);
*ierr = PetscMPIDataTypeToPetscDataType(dtype, &pdtype);if (*ierr)
return;
*ierr = F90Array1dAccess(rptr, pdtype, (void**) &rootdata
*ierr = F90Array1dAccess(lptr, pdtype, (void**) &leafdata
*ierr = PetscSFBcastBegin(*sf, dtype, rootdata, leafdata);
The problem is this only seems to work if I declare the datatype in the
calling Fortran code to be of the appropriate C MPI datatype, e.g.
MPI_INT, rather than the corresponding Fortran datatype, e.g.
MPI_INTEGER (which causes PetscMPIDataTypeToPetscDataType() to fail, as
something weird gets passed in for dtype).
I was expecting the opposite to be true. It doesn't seem right to have
to use the C datatypes in Fortran code (confusing if the Fortran
datatypes are used elsewhere). So I suspect I've messed something up.
Anyone have any ideas?
- Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171020/7d4d9cb0/attachment.html>
