[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2017-10-17
Satish Balay
balay at mcs.anl.gov
Tue Oct 17 15:57:00 CDT 2017
pushed to knepley/feature-adaptor-plex
https://bitbucket.org/petsc/petsc/commits/54c8e91ecbda26974e0050fcf2abbba3ecc87a6b
For eg: http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/10/17/make_next_arch-cuda-double_es.log
The above fixes the following error that has been aborting nightlybuilds for past couple of days.
/sandbox/petsc/petsc.clone/include/../src/snes/f90-mod/ftn-auto-interfaces/petscsnes.h90:574.7:
Included at /sandbox/petsc/petsc.clone/src/snes/f90-mod/petscsnesmod.F:45:
DMAdaptationStrategy c ! DMAdaptationStrategy
1
Error: Unclassifiable statement at (1)
make[2]: *** [arch-cuda-double/obj/src/snes/f90-mod/petscsnesmod.o] Error 1
Also fixes this warning
/sandbox/petsc/petsc.clone/src/snes/utils/ftn-auto/dmadaptf.c: In function ‘petscglobalminmax_’:
/sandbox/petsc/petsc.clone/src/snes/utils/ftn-auto/dmadaptf.c:125:1: warning: implicit declaration of function ‘PetscGlobalMinMax’ [-Wimplicit-function-declaration]
*__ierr = PetscGlobalMinMax(
Satish
On Tue, 17 Oct 2017, Matthew Knepley wrote:
> I already pushed a fix this morning. What did you push?
> Matt
> On Tue, Oct 17, 2017 at 3:59 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > This has been broken for a couple of days. I pushed a fix [hoping
> > builds don't abort anymore] - but there are more things to fix..
> > Satish
> > On Tue, 17 Oct 2017, PETSc checkBuilds wrote:
> > > Dear PETSc developer,
> > > This email contains listings of contributions attributed to you by
> > > `git blame` that caused compiler errors or warnings in PETSc automated
> > > testing. Follow the links to see the full log files. Please attempt to
> > fix
> > > the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are
> > unable
> > > to resolve the issues.
> > > Thanks,
> > > The PETSc development team
> > > warnings attributed to commit https://bitbucket.org/petsc/
> > petsc/commits/5675c17
> > > DM: Added DMAdaptor
> > > src/snes/utils/dmadapt.c:610
> > > [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/
> > 2017/10/17/build_next_arch-linux-c89_el6.log]
> > > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:610:5:
> > error: expected expression before '/' token
> > > src/snes/utils/dmadapt.c:611
> > > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:611:5:
> > > src/snes/utils/dmadapt.c:710
> > 2017/10/17/build_next_arch-osx-10.6-cxx-pkgs-opt_ipro.log]
> > > /Users/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:710:16:
> > error: no matching function for call to 'PetscFECreateDefault'
> > 2017/10/17/build_next_arch-freebsd-cxx-pkgs-opt_wii.log]
> > > /usr/home/balay/petsc.clone-2/src/snes/utils/dmadapt.c:710:110:
> > error: cannot convert 'bool' to 'PetscBool' for argument '4' to
> > 'PetscErrorCode PetscFECreateDefault(DM, PetscInt, PetscInt, PetscBool,
> > const char*, PetscInt, _p_PetscFE**)'
> > 2017/10/17/build_next_arch-linux-xsdk-dbg_cg.log]
> > > /sandbox/petsc/petsc.clone/src/snes/utils/dmadapt.c:710:110:
> > 2017/10/17/build_next_arch-osx-10.6-cxx-cmplx-pkgs-dbg_ipro.log]
> > > /Users/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:710:16:
> > 2017/10/17/build_next_arch-linux-opt-cxx-quad_grind.log]
> > > /sandbox/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:710:110:
> > 2017/10/17/build_next_arch-freebsd-cxx-cmplx-pkgs-dbg_wii.log]
> > > /usr/home/balay/petsc.clone/src/snes/utils/dmadapt.c:710:110:
> > 2017/10/17/build_next_arch-linux-pkgs-cxx-mlib_el6.log]
> > 2017/10/17/build_next_arch-linux-cxx-cmplx-pkgs-64idx_churn.log]
> > > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:710:16:
> > 2017/10/17/build_next_arch-linux-xsdk-latest_cg.log]
> > > /sandbox/petsc/petsc.clone-4/src/snes/utils/dmadapt.c:710:110:
> > 2017/10/17/build_next_arch-linux-gcc-absoft_crank.log]
> > > src/snes/utils/dmadapt.c:712
> > > /usr/home/balay/petsc.clone/src/snes/utils/dmadapt.c:712:104:
> > > /sandbox/petsc/petsc.clone/src/snes/utils/dmadapt.c:712:104:
> > > /sandbox/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:712:104:
> > > /Users/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:712:16:
> > > /usr/home/balay/petsc.clone-2/src/snes/utils/dmadapt.c:712:104:
> > > /Users/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:712:16:
> > > /sandbox/petsc/petsc.clone-4/src/snes/utils/dmadapt.c:712:104:
> > > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:712:16:
> > > src/snes/utils/dmadapt.c:765
> > 2017/10/17/build_next_arch-linux-gcc-ifc-cmplx_crank.log]
> > > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:765:9:
> > warning: passing argument 2 of 'DMPlex_Det2D_Internal' from incompatible
> > pointer type [enabled by default]
> > > /usr/home/balay/petsc.clone/src/snes/utils/dmadapt.c:765:59:
> > error: cannot convert 'const PetscScalar* {aka const
> > std::complex<double>*}' to 'const PetscReal* {aka const double*}' for
> > argument '2' to 'void DMPlex_Det2D_Internal(PetscReal*, const PetscReal*)'
> > > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:765:28:
> > error: no matching function for call to 'DMPlex_Det2D_Internal'
> > > /Users/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:765:28:
> > > src/snes/utils/dmadapt.c:766
> > > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:766:28:
> > error: no matching function for call to 'DMPlex_Det3D_Internal'
> > > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:766:9:
> > warning: passing argument 2 of 'DMPlex_Det3D_Internal' from incompatible
> > > /usr/home/balay/petsc.clone/src/snes/utils/dmadapt.c:766:59:
> > argument '2' to 'void DMPlex_Det3D_Internal(PetscReal*, const PetscReal*)'
> > > /Users/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:766:28:
> > petsc/commits/59b28e7
> > > DMAdaptor: Now adaptation can change the DM and solution Vec
> > > src/snes/utils/dmadapt.c:15
> > > /Users/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:15:10: error:
> > no matching function for call to 'DMProjectFunction'
> > > /sandbox/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:15:83:
> > error: invalid conversion from 'void*' to 'void**' [-fpermissive]
> > > /usr/home/balay/petsc.clone-2/src/snes/utils/dmadapt.c:15:83:
> > > /sandbox/petsc/petsc.clone-4/src/snes/utils/dmadapt.c:15:83:
> > > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:15:10:
> > error: no matching function for call to 'DMProjectFunction'
> > > /Users/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:15:10: error:
> > > /sandbox/petsc/petsc.clone/src/snes/utils/dmadapt.c:15:83: error:
> > > /usr/home/balay/petsc.clone/src/snes/utils/dmadapt.c:15:83:
> > petsc/commits/7c88af5
> > > SNES: Added -snes_adapt_sequence
> > > src/snes/interface/snes.c:4113
> > 2017/10/17/build_next_arch-linux-pkgs-valgrind_el6.log]
> > > /sandbox/petsc/petsc.clone-4/src/snes/interface/snes.c:4113:9:
> > warning: implicit declaration of function 'DMAdaptorSetSequenceLength'
> > 2017/10/17/build_next_arch-linux-uni_crush.log]
> > > /sandbox/petsc/petsc.clone-2/src/snes/interface/snes.c:4113:9:
> > 2017/10/17/build_next_arch-linux-opt-misc_el6.log]
> > > /sandbox/petsc/petsc.clone/src/snes/interface/snes.c:4113:9:
> > 2017/10/17/build_next_arch-linux-pkgs-opt_crank.log]
> > 2017/10/17/build_next_arch-viennacl_es.log]
> > 2017/10/17/build_next_arch-linux-pkgs-dbg-ftn-interfaces_churn.log]
> > > /sandbox/petsc/petsc.clone/src/snes/interface/snes.c:4113:16:
> > warning: implicit declaration of function 'DMAdaptorSetSequenceLength' is
> > invalid in C99 [-Wimplicit-function-declaration]
> > 2017/10/17/build_next_arch-linux-dbg-quad_churn.log]
> > > /sandbox/petsc/petsc.clone-3/src/snes/interface/snes.c:4113:16:
> > warning: implicit declaration of function 'DMAdaptorSetSequenceLength'; did
> > you mean 'DMAdaptorSetSolver'? [-Wimplicit-function-declaration]
> > 2017/10/17/build_next_arch-linux-without-fc_cg.log]
> > 2017/10/17/build_next_arch-cuda-single_es.log]
> > 2017/10/17/build_next_arch-linux-IPL64_thrash.log]
> > 2017/10/17/build_next_arch-linux-pkgs-64idx_thrash.log]
> > > /sandbox/petsc/petsc.clone-3/src/snes/interface/snes.c:4113:9:
> > 2017/10/17/build_next_arch-linux-clang-avx_knl.log]
> > > /home/petsc/petsc.clone-2/src/snes/interface/snes.c:4113:16:
> > 2017/10/17/build_next_arch-freebsd-pkgs-opt_wii.log]
> > > /usr/home/balay/petsc.clone-3/src/snes/interface/snes.c:4113:16:
> > 2017/10/17/build_next_arch-cuda-double_es.log]
> > 2017/10/17/build_next_arch-osx-10.6_ipro.log]
> > > /Users/petsc/petsc.clone/src/snes/interface/snes.c:4113:16:
> > 2017/10/17/build_next_arch-c-exodus-dbg-builder_es.log]
> > 2017/10/17/build_next_arch-osx-xsdk-opt_ipro.log]
> > > /Users/petsc/petsc.clone-4/src/snes/interface/snes.c:4113:16:
> > petsc/commits/8df224e
> > > DMAdapt: Thanks to Nicolas, this is now working
> > > src/snes/utils/dmadapt.c:506
> > > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:506:7:
> > error: too few arguments to function 'zheev_'
> > warning: passing argument 6 of 'zheev_' from incompatible pointer type
> > warning: passing argument 9 of 'zheev_' from incompatible pointer type
> > > /usr/home/balay/petsc.clone/src/snes/utils/dmadapt.c:506:95:
> > error: cannot convert 'PetscScalar* {aka std::complex<double>*}' to
> > 'PetscReal* {aka double*}' for argument '6' to 'void zheev_(const char*,
> > const char*, PetscBLASInt*, PetscScalar*, PetscBLASInt*, PetscReal*,
> > PetscScalar*, PetscBLASInt*, PetscReal*, PetscBLASInt*)'
> > > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:506:39:
> > error: no matching function for call to 'zheev_'
> > > /Users/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:506:39:
> > > src/snes/utils/dmadapt.c:567
> > > /Users/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:567:22:
> > > /usr/home/balay/petsc.clone/src/snes/utils/dmadapt.c:567:52:
> > > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:567:22:
> > > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:567:3:
> > > src/snes/utils/dmadapt.c:568
> > > /Users/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:568:22:
> > > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:568:22:
> > > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:568:3:
> > > /usr/home/balay/petsc.clone/src/snes/utils/dmadapt.c:568:52:
> > > To opt-out from receiving these messages - send a request to
> > petsc-dev at mcs.anl.gov.
