[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2017-10-17
Matthew Knepley
knepley at gmail.com
Tue Oct 17 15:51:37 CDT 2017
I already pushed a fix this morning. What did you push?
Matt
On Tue, Oct 17, 2017 at 3:59 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> This has been broken for a couple of days. I pushed a fix [hoping
> builds don't abort anymore] - but there are more things to fix..
> Satish
> On Tue, 17 Oct 2017, PETSc checkBuilds wrote:
> > Dear PETSc developer,
> > This email contains listings of contributions attributed to you by
> > `git blame` that caused compiler errors or warnings in PETSc automated
> > testing. Follow the links to see the full log files. Please attempt to
> fix
> > the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are
> unable
> > to resolve the issues.
> > Thanks,
> > The PETSc development team
> > warnings attributed to commit https://bitbucket.org/petsc/
> petsc/commits/5675c17
> > DM: Added DMAdaptor
> > src/snes/utils/dmadapt.c:610
> > [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/
> 2017/10/17/build_next_arch-linux-c89_el6.log]
> > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:610:5:
> error: expected expression before '/' token
> > src/snes/utils/dmadapt.c:611
> > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:611:5:
> > src/snes/utils/dmadapt.c:710
> 2017/10/17/build_next_arch-osx-10.6-cxx-pkgs-opt_ipro.log]
> > /Users/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:710:16:
> error: no matching function for call to 'PetscFECreateDefault'
> 2017/10/17/build_next_arch-freebsd-cxx-pkgs-opt_wii.log]
> > /usr/home/balay/petsc.clone-2/src/snes/utils/dmadapt.c:710:110:
> error: cannot convert 'bool' to 'PetscBool' for argument '4' to
> 'PetscErrorCode PetscFECreateDefault(DM, PetscInt, PetscInt, PetscBool,
> const char*, PetscInt, _p_PetscFE**)'
> 2017/10/17/build_next_arch-linux-xsdk-dbg_cg.log]
> > /sandbox/petsc/petsc.clone/src/snes/utils/dmadapt.c:710:110:
> 2017/10/17/build_next_arch-osx-10.6-cxx-cmplx-pkgs-dbg_ipro.log]
> > /Users/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:710:16:
> 2017/10/17/build_next_arch-linux-opt-cxx-quad_grind.log]
> > /sandbox/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:710:110:
> 2017/10/17/build_next_arch-freebsd-cxx-cmplx-pkgs-dbg_wii.log]
> > /usr/home/balay/petsc.clone/src/snes/utils/dmadapt.c:710:110:
> 2017/10/17/build_next_arch-linux-pkgs-cxx-mlib_el6.log]
> 2017/10/17/build_next_arch-linux-cxx-cmplx-pkgs-64idx_churn.log]
> > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:710:16:
> 2017/10/17/build_next_arch-linux-xsdk-latest_cg.log]
> > /sandbox/petsc/petsc.clone-4/src/snes/utils/dmadapt.c:710:110:
> 2017/10/17/build_next_arch-linux-gcc-absoft_crank.log]
> > src/snes/utils/dmadapt.c:712
> > /usr/home/balay/petsc.clone/src/snes/utils/dmadapt.c:712:104:
> > /sandbox/petsc/petsc.clone/src/snes/utils/dmadapt.c:712:104:
> > /sandbox/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:712:104:
> > /Users/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:712:16:
> > /usr/home/balay/petsc.clone-2/src/snes/utils/dmadapt.c:712:104:
> > /Users/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:712:16:
> > /sandbox/petsc/petsc.clone-4/src/snes/utils/dmadapt.c:712:104:
> > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:712:16:
> > src/snes/utils/dmadapt.c:765
> 2017/10/17/build_next_arch-linux-gcc-ifc-cmplx_crank.log]
> > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:765:9:
> warning: passing argument 2 of 'DMPlex_Det2D_Internal' from incompatible
> pointer type [enabled by default]
> > /usr/home/balay/petsc.clone/src/snes/utils/dmadapt.c:765:59:
> error: cannot convert 'const PetscScalar* {aka const
> std::complex<double>*}' to 'const PetscReal* {aka const double*}' for
> argument '2' to 'void DMPlex_Det2D_Internal(PetscReal*, const PetscReal*)'
> > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:765:28:
> error: no matching function for call to 'DMPlex_Det2D_Internal'
> > /Users/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:765:28:
> > src/snes/utils/dmadapt.c:766
> > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:766:28:
> error: no matching function for call to 'DMPlex_Det3D_Internal'
> > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:766:9:
> warning: passing argument 2 of 'DMPlex_Det3D_Internal' from incompatible
> > /usr/home/balay/petsc.clone/src/snes/utils/dmadapt.c:766:59:
> argument '2' to 'void DMPlex_Det3D_Internal(PetscReal*, const PetscReal*)'
> > /Users/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:766:28:
> petsc/commits/59b28e7
> > DMAdaptor: Now adaptation can change the DM and solution Vec
> > src/snes/utils/dmadapt.c:15
> > /Users/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:15:10: error:
> no matching function for call to 'DMProjectFunction'
> > /sandbox/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:15:83:
> error: invalid conversion from 'void*' to 'void**' [-fpermissive]
> > /usr/home/balay/petsc.clone-2/src/snes/utils/dmadapt.c:15:83:
> > /sandbox/petsc/petsc.clone-4/src/snes/utils/dmadapt.c:15:83:
> > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:15:10:
> error: no matching function for call to 'DMProjectFunction'
> > /Users/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:15:10: error:
> > /sandbox/petsc/petsc.clone/src/snes/utils/dmadapt.c:15:83: error:
> > /usr/home/balay/petsc.clone/src/snes/utils/dmadapt.c:15:83:
> petsc/commits/7c88af5
> > SNES: Added -snes_adapt_sequence
> > src/snes/interface/snes.c:4113
> 2017/10/17/build_next_arch-linux-pkgs-valgrind_el6.log]
> > /sandbox/petsc/petsc.clone-4/src/snes/interface/snes.c:4113:9:
> warning: implicit declaration of function 'DMAdaptorSetSequenceLength'
> [-Wimplicit-function-declaration]
> 2017/10/17/build_next_arch-linux-uni_crush.log]
> > /sandbox/petsc/petsc.clone-2/src/snes/interface/snes.c:4113:9:
> 2017/10/17/build_next_arch-linux-opt-misc_el6.log]
> > /sandbox/petsc/petsc.clone/src/snes/interface/snes.c:4113:9:
> 2017/10/17/build_next_arch-linux-pkgs-opt_crank.log]
> 2017/10/17/build_next_arch-viennacl_es.log]
> 2017/10/17/build_next_arch-linux-pkgs-dbg-ftn-interfaces_churn.log]
> > /sandbox/petsc/petsc.clone/src/snes/interface/snes.c:4113:16:
> warning: implicit declaration of function 'DMAdaptorSetSequenceLength' is
> invalid in C99 [-Wimplicit-function-declaration]
> 2017/10/17/build_next_arch-linux-dbg-quad_churn.log]
> > /sandbox/petsc/petsc.clone-3/src/snes/interface/snes.c:4113:16:
> warning: implicit declaration of function 'DMAdaptorSetSequenceLength'; did
> you mean 'DMAdaptorSetSolver'? [-Wimplicit-function-declaration]
> 2017/10/17/build_next_arch-linux-without-fc_cg.log]
> 2017/10/17/build_next_arch-cuda-single_es.log]
> 2017/10/17/build_next_arch-linux-IPL64_thrash.log]
> 2017/10/17/build_next_arch-linux-pkgs-64idx_thrash.log]
> > /sandbox/petsc/petsc.clone-3/src/snes/interface/snes.c:4113:9:
> 2017/10/17/build_next_arch-linux-clang-avx_knl.log]
> > /home/petsc/petsc.clone-2/src/snes/interface/snes.c:4113:16:
> 2017/10/17/build_next_arch-freebsd-pkgs-opt_wii.log]
> > /usr/home/balay/petsc.clone-3/src/snes/interface/snes.c:4113:16:
> 2017/10/17/build_next_arch-cuda-double_es.log]
> 2017/10/17/build_next_arch-osx-10.6_ipro.log]
> > /Users/petsc/petsc.clone/src/snes/interface/snes.c:4113:16:
> 2017/10/17/build_next_arch-c-exodus-dbg-builder_es.log]
> 2017/10/17/build_next_arch-osx-xsdk-opt_ipro.log]
> > /Users/petsc/petsc.clone-4/src/snes/interface/snes.c:4113:16:
> petsc/commits/8df224e
> > DMAdapt: Thanks to Nicolas, this is now working
> > src/snes/utils/dmadapt.c:506
> > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:506:7:
> error: too few arguments to function 'zheev_'
> warning: passing argument 6 of 'zheev_' from incompatible pointer type
> warning: passing argument 9 of 'zheev_' from incompatible pointer type
> > /usr/home/balay/petsc.clone/src/snes/utils/dmadapt.c:506:95:
> error: cannot convert 'PetscScalar* {aka std::complex<double>*}' to
> 'PetscReal* {aka double*}' for argument '6' to 'void zheev_(const char*,
> const char*, PetscBLASInt*, PetscScalar*, PetscBLASInt*, PetscReal*,
> PetscScalar*, PetscBLASInt*, PetscReal*, PetscBLASInt*)'
> > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:506:39:
> error: no matching function for call to 'zheev_'
> > /Users/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:506:39:
> > src/snes/utils/dmadapt.c:567
> > /Users/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:567:22:
> > /usr/home/balay/petsc.clone/src/snes/utils/dmadapt.c:567:52:
> > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:567:22:
> > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:567:3:
> > src/snes/utils/dmadapt.c:568
> > /Users/petsc/petsc.clone-3/src/snes/utils/dmadapt.c:568:22:
> > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:568:22:
> > /sandbox/petsc/petsc.clone-2/src/snes/utils/dmadapt.c:568:3:
> > /usr/home/balay/petsc.clone/src/snes/utils/dmadapt.c:568:52:
> > To opt-out from receiving these messages - send a request to
> petsc-dev at mcs.anl.gov.
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171017/d3aec107/attachment-0001.html>
