[petsc-dev] Discussion about time-dependent optimization moved from PR
Stefano Zampini
stefano.zampini at gmail.com
Tue Oct 17 07:43:06 CDT 2017
> What happens if you call TSCreateAdjointsTS() on a TS obtained with
> TSCreateAdjointsTS()? Is the resulting TS useful?
I don't think so. Theoretically, it should be a tangent linear model with a
different forcing function
> Barry
> > On Oct 17, 2017, at 12:37 AM, Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
> > >> In case of multiple objectives, there may be a performance reason to
> > >> amortize evaluation of several at once, though the list interface is
> > >> convenient. Consider common objectives being quantities like lift and
> > >> drag on different surfaces of a fluids simulation or stress/strain at
> > >> certain critical joints in a structure. Although these have some
> > >> locality, it's reasonable to assume that state dependence will have
> > >> quickly become global, thus make no attempt to handle sparse
> > >> representations of the adjoint vectors lambda.
> > > I don't get this comment. Is it related with multi-objective
> optimization
> > > (e.g. Pareto)?
> > Adjoints are usually preferred any time you are differentiating a small
> > number of output variables with respect to a large number of inputs. It
> > could be for multi-objective optimization, but it's every bit as
> > relevant for physical sensitivities.
> > If we are not talking about Pareto optimization, and thus we don't need
> a separate output from each function, then users can pass a single function
> that computes all the quantities they need at the same time. Anyway, I
> don't mind having a single callback for multiple functions.
> > >> How are parameters accessed in TSComputeRHSFunction? It looks like
> > >> they're coming out of the context. Why should this be different? (If
> > >> parameters need to go into a Vec, we could do that, but it comes at a
> > >> readability and possibly parallel cost if the global Vec needs to be
> > >> communicated to local vectors.)
> > > design paramaters are fixed troughout an adjoint/tlm run. They can be
> > > communicated locally once at the beginning of the run.
> > > This is what TSSetUpFromDesign and TSSetSetUpFromDesign are supposed to
> > > handle, if I get your comment.
> > My point is that users currently get design parameters out of the
> > context when evaluating their RHSFunction and friends. If that is the
> > endorsed way to access design variables, then your new function doesn't
> > need to pass the vector. If you need to pass the parameter vector in
> > that one function, instead of obtaining them from the context, then
> > you'd need to pass the parameter vector everywhere and discourage using
> > the context for active design variables. I think there are merits to
> > both approaches, but it absolutely needs to be consistent.
> > So, to be consistent, we have to force users to perform an operation in
> a single way?
> > Yes, TSSetUpFromDesign is among the last things I have added, and allows
> to update the application context (among other things, as it is very
> general). I can remove the parameter vector from TSEvalGradientDAE and
> TSEvalGradientIC; however, having these vectors there makes it clear that
> we allow non-linear dependency on the parameters too. I can add a comment
> on the man pages that the vectors are guaranteed to be the same one passed
> in my TSSetUpFromDesign, or remove them. Your call.
> > Users can do anything they want with the forward model context, but they
> are not free to change the application context of the adjoints TS. Maybe
> this should be improved by adding and extra slot to AdjointTSCtx to carry
> over the user context (for the adjoint I mean)?
> > > https://bitbucket.org/petsc/petsc/src/c2e9112e7fdfd89985f9ffc4d68b0d
> 46cf7cad52/src/ts/interface/tspdeconstrainedutils.c?at=
> stefano_zampini%2Ffeature-continuousadjoint&fileviewer=file-view-default#
> tspdeconstrainedutils.c-579
> > > Here is how ex23.c uses it
> 46cf7cad52/src/ts/examples/tutorials/ex23.c?at=stefano_zampini%2Ffeature-
> continuousadjoint&fileviewer=file-view-default#ex23.c-677
> > And yet you redo the scatter here instead of using what you stuffed into
> > the context. If you needed to redo it for correctness, you'd also need
> > to in every other function that accesses design parameters.
> continuousadjoint&fileviewer=file-view-default#ex23.c-274
> > This is a leftover from a previous version of the code (there's also a
> comment) that was not using TSSetSetUpFromDesign and it's definitely not
> needed.
> > >> > Both methods need the Jacobian of the DAE wrt the parameters: H
> > >> > TSAdjointSetRHSJacobian(), S TSSetGradientDAE()
> > >> > Initial condition dependence on the parameters is implicitly
> computed in
> > >> > Hong's code (limited to linear dependence on all the variables);
> > >> How so? Once the user gets \lambda(time=0), they can apply the chain
> > >> rule to produce any dependency on the parameter vector?
> > >> Yes, the chain rule is implemented here
> tspdeconstrainedutils.c-254
> > I know you have a callback for it, but Hong's interface is plenty
> > functional for such systems, they just call that derivative instead of
> > writing and registering a function to do that.
> > I'm not saying HOng's interface is not functional. The initial condition
> gradients allow to automatize the process in TSComputeObjectiveAndGradient(),
> TSComputeHessian(), and MatMult_Propagator(). Anyway, the lambda variables
> are not modified by AdjointTSComputeFinalGradient() (that adds the IC
> dependency) and users can do whatever they want with them.
> > I know you don't like TSComputeObjectiveAndGradient(), but it's a code
> that anyway users have to write to compute a gradient of the DAE not
> arising from a PDAE. How can this be automatized for PDAEs? Should we store
> the AdjointTS inside the model TS and use TSGetAdjointTS(ts,&ts->adjts) with
> > TSGetAdjointTS(TS f,TS* a) {
> > if (!f->adjtts) TSCreateAdjointsTS(f,&f->adjts);
> > *a = f->adjts:
> > and the corresponding Setter to allow users to do
> > TSCreateAdjointTS(ts,&atts)
> > TSSetRHSJacobian(ats,...)
> > TSSetAdjointTS(ts,ats)
> > or
> > TSGetAdjointTS(ts,&atts)
> > Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171017/9cc32ee4/attachment-0001.html>
