[petsc-dev] PetscSF in Fortran
Adrian Croucher a.croucher at auckland.ac.nz
Thu Oct 12 23:25:00 CDT 2017
hi Jed
I have had a go at writing a Fortran binding for the PetscSFGetGraph()
function, along the lines of what you suggested:
> On 21/09/17 15:15, Jed Brown wrote:
> Unfortunately PetscSFSetGraph/PetscSFGetGraph need custom bindings for
> Fortran and they have not been written.  Shouldn't be difficult, but
> will take a little work/testing.  I would probably make the array of
> PetscSFNode be a PetscInt array of length 2n (or of shape (2,n)) --
> that's an equivalent memory representation to what we're using now.
 From looking at various other existing custom Fortran bindings that
return arrays, I tried the following:
PETSC_EXTERN void PETSC_STDCALL petscsfgetgraph_(PetscSF *sf, PetscInt
*nroots, PetscInt *nleaves, F90Array1d *lptr, F90Array2d *rptr, int
*ierr PETSC_F90_2PTR_PROTO(lptrd) PETSC_F90_2PTR_PROTO(rptrd))
   const PetscInt *ilocal;
   const PetscSFNode *iremote;
   *ierr = PetscSFGetGraph(*sf, nroots, nleaves, &ilocal, &iremote); if
(*ierr) return;
   *ierr = F90Array1dCreate((void*) ilocal, PETSC_INT, 1, *nleaves, lptr
PETSC_F90_2PTR_PARAM(lptrd));
   *ierr = F90Array2dCreate((void*) iremote, PETSC_INT, 1, 2, 1,
*nleaves, rptr PETSC_F90_2PTR_PARAM(rptrd));
I put this in a new file zsff90.c, in a new directory
/vec/is/sf/interface/f90-custom/, together with an appropriate makefile.
However it crashes with a segmentation violation in the call to
F90Array1dCreate(), when that goes into the Fortran routine
F90Array1dCreateInt() and tries to assign the pointer.
In my test calling program I declare the arrays for ilocal and iremote
as PetscInt, pointer :: ilocal(:), iremote(:,:) and pass them in.
Any clues? I have tried various variations on the above but I suspect
I've either made some basic mistake or I just don't understand how this
should be done.
- Adrian
On 28/09/17 15:34, Adrian Croucher wrote:
> hi
> On 28/09/17 04:18, Matthew Knepley wrote:
>> Okay, I think this should be easy to solve.
>> First a little bit about SF. There are two parts to the
>> specification. You have the communication part, which maps
>> a certain location p on this process to another location q on another
>> process. This might not change for you. The
>> second part just tells it how big the data array is (numRoots), which
>> is the thing that the locations in the communication
>> part index into.
>> So my question is, where did you put the numbers for the points you
>> added? Are they after all points, or only after the old cells?
>> I think you can easily create the new SF using the info from
>> SFGetGraph().
> I've had a closer look at how the SF stuff works (partly by viewing
> the point SF from the original DM) and I think I understand it now.
> There were two things I hadn't realised:
> 1) It looks like all DM points are always considered potential roots
> for leaves on another process, which is why it complained with an
> error message when the number of roots was less than pEnd . I don't
> think this really makes so much sense in the dual-porosity mesh case
> I'm working on, because the new points I'm adding are all 'inside' the
> original cells and have no possible connection with any other points.
> So they can't be roots for any off-process leaf points. But I guess it
> won't hurt to tell it that they can (by increasing the number of roots
> passed to PetscSFSetGraph so it's equal to the new pEnd).
> 2) Because I'm doing finite volume I had only thought about ghost
> cells, but the SF needs to include leaf points in other height strata
> as well (vertices, edges and faces). My new points in each stratum
> have been added after the partition ghost points, so the leaf cells
> won't have changed their point indices. However the leaf points in
> other strata will have been shifted (because of points added into
> preceding strata).
> So I think I will need to use PetscSFSetGraph() after all, so I can
> increase the number of roots, update the leaf point indices, and also
> update the remote root index for each leaf (presumably I can use the
> original SF and PetscSFBcastBegin/ PetscSFBcastEnd to do that).
> If you agree, then I will need working Fortran interfaces to the
> PetscSFGetGraph/ PetscSFSetGraph functions, which are missing at
> present. Are you able to add those easily?
> Thanks,
> Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171013/8017437e/attachment-0001.html>
