[petsc-dev] Plex web pages are broken
Jed Brown jed at jedbrown.org
Thu Oct 12 17:22:15 CDT 2017
Satish Balay <balay at mcs.anl.gov> writes:
> Hm - for each patch release - we just untar the tarball on the website
> For now - I can just copy these files over from DMPLEX to DM
> ok - done.
Thanks.  If we're moving their location, it should really have a redirect.
In the longer term, why should our paths have this structure?  I'd
rather flatten that directory structure.
http://www.mcs.anl.gov/petsc/petsc-3.8/docs/manualpages/DMPlexGetTransitiveClosure.html
> Satish
> On Thu, 12 Oct 2017, Jed Brown wrote:
>> Would it be too much work to set redirects?
>> > Yes - petsc-3.7 had these in 'DM' and petsc-3.8 created a new section
>> > 'DMPLEX' - so it might take a while for google to use this change..
>> > http://www.mcs.anl.gov/petsc/petsc-3.7/docs/manualpages/DM/DMPlexGetTransitiveClosure.html
>> > http://www.mcs.anl.gov/petsc/petsc-3.8/docs/manualpages/DMPLEX/DMPlexGetTransitiveClosure.html
>> > Satish
>> > On Thu, 12 Oct 2017, Mark Adams wrote:
>> >> Humm, this one fails also. slightly different problem (using DM directory):
>> >> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMPlexGetTransitiveClosure.html
>> >> Maybe Google has old pointers ...
>> >> On Thu, Oct 12, 2017 at 12:31 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> >> > Google is returning (for me):
>> >> > www.mcs.anl.gov/petsc/petsc-current/docs/.../DM/DMPlexGetDepthStratum.html
>> >> > I tested two Plex methods, both had this .../DM thing that does not work.
>> >> > Other PETSc methods seem fine.
>> >> > On Thu, Oct 12, 2017 at 12:11 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> >> >> Well the page is at
>> >> >> DMPLEX/DMPlexGetDepthStratum.html
>> >> >> Does some other doc have this incorrect URL?
>> >> >> Satish
>> >> >> > FYI, It looks like the Plex method we pages are dead, such as:
>> >> >> > http://www.mcs.anl.gov/petsc/petsc-current/docs/.../DM/DMPle
