[petsc-dev] development version for MATAIJMKL type mat
Tue Oct 10 13:50:45 CDT 2017
> On Oct 10, 2017, at 10:52 AM, Bakytzhan Kallemov <bkallemov at lbl.gov> wrote:
> Hi,
> My name is Baky Kallemov.
> Currently, I am working on improving a scalibility of  the Chombo-Petsc interface on cori machine at nersc system.
> I successfully build the libs from master branch with --with-openmp and hypre.
> However, I have not noticed any difference running my test problem on single node KNL node using new MATAIJMKL
  hyre uses its own matrix operations so it won't get faster when using running PETSc with MATAIJMKL or any other specific matrix type.
> type for different hybrid mpi+openmp runs  compared to regular released version.
   What are you comparing? Are you using say 32 MPI processes and 2 threads or 16 MPI processes and 4 threads? How are you controlling the number of OpenMP threads, OpenMP environmental variable? What parts of the time in the code are you comparing? You should just -log_view and compare the times for PCApply and PCSetUp() between say 64 MPI process/1 thread and 32 MPI processes/2 threads and send us the output for those two cases.
> It seems that it made no difference, so perhaps I am doing something wrong or my build is not configured right.
> Do you have any example that makes use of threads when running hybrid and show an advantage?
   There is not reason to think that using threads on KNL is faster than just using MPI processes. Despite what the NERSc/LBL web pages may say, just because a website says something doesn't make it true.
> I'd like to test it and make sure that my libs are configured correctly, before start to investigate it further.
> Thanks,
> Baky
