[petsc-dev] Mat Type: HYPRE
Stefano Zampini
stefano.zampini at gmail.com
Wed Oct 4 03:27:06 CDT 2017
Does this error arise at the first assembly of the matrix or in a
successive assembly?
In the second case, I guess the issue is with HYPRE, or the way we are
passing the preallocation to HYPRE routines.
For some reasons that I'm not aware of, reassembling an HypreParCSR matrix
may have issues.
My knowledge of the HYPRE code is not so deep to tell you why.
2017-10-04 1:03 GMT+03:00 Kong, Fande <fande.kong at inl.gov>:
> Hi ALL,
> There is a new Mat type: HYPRE in PETSc. I would like to try it out
> because it may save the memory if use a hypre preconditioner. When use a
> native PETSc type such as MPIAIJ, we need to keep an extra copy of Jacobian
> matrix usually for the hypre preconditioner.
> I was wondering if or not Mat HYPRE is complete. There are some errors
> when I am tring to use it. The code works fine with MPIAIJ.
> [0]PETSC ERROR: --------------------- Error Message
> -------------------------------------------------------------- [0]PETSC
> ERROR: Error in external library [0]PETSC ERROR: Error in
> HYPRE_IJMatrixAddToValues(): error code 1 [0]PETSC ERROR: See
> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.8-2-gd4ad237 GIT Date:
> 2017-10-03 12:37:25 -0600 [0]PETSC ERROR: ../../../moose_test-opt on a
> arch-darwin-c-debug-master named FN604208 by kongf Tue Oct 3 15:54:15 2017
> [0]PETSC ERROR: Configure options --with-debugging=yes
> --with-shared-libraries=1 --with-mpi=1 --download-fblaslapack=1
> --download-metis=1 --download-parmetis=1 --download-superlu_dist=1
> --download-hypre=1 --download-mumps=1 --download-scalapack=1
> PETSC_ARCH=arch-darwin-c-debug-master [0]PETSC ERROR: #1
> MatSetValues_HYPRE() line 1014 in /Users/kongf/projects/petsc/src/mat/impls/hypre/mhypre.c
> [0]PETSC ERROR: #2 MatSetValues() line 1270 in /Users/kongf/projects/petsc/src/mat/interface/matrix.c
> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0 [unset]:
> write_line error; fd=-1 buf=:cmd=abort exitcode=1 : system msg for
> write_line failure : Bad file descriptor
> Fande,
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171004/63070209/attachment.html>
