[petsc-dev] remove temporary output with new test-harness
    Matthew Knepley
    knepley at gmail.com
    Wed Nov 29 11:25:49 CST 2017
On Wed, Nov 29, 2017 at 11:23 AM, Scott Kruger <kruger at txcorp.com> wrote:
> The generated scripts automatically run in a subdirectory to avoid name
> conflicts.  For example, runex1.sh creates a runex1 directory relative
> to its location and then runs the actual test in there.  These temporary
> directories are not removed automatically by the test harness as it hasn't
> been a problem yet.
Okay, then it would be nice to give a list of files to be removed after the
test.
     Matt
> Scott
> On 11/29/17 9:43 AM, Matthew Knepley wrote:
>> On Wed, Nov 29, 2017 at 10:38 AM, Scott Kruger <kruger at txcorp.com
>> <mailto:kruger at txcorp.com>> wrote:
>>     rm $PETSC_ARCH/tests/<path_to_file>/<file>
>>     I assume you really mean something else, specifically related to the
>>     generated test script, but there isn't enough information to answer
>>     that.
>>     Or more specifically, the test language was not written to generate
>>     scripts that have an `rm` command in them, so perhaps explaining why
>>     an extension would be a good idea.]
>> I think what Stefano means is the following;
>>    I write a test for the HDF5 Viewer. It creates a file called
>> "vector.dat". I want it removed at the end of the test.
>> I think the answer is, the test directory is blown away, so as long as
>> the file is in that temp dir, you are fine.
>>    Thanks,
>>       Matt
>>     Scott
>>     On 11/29/17 6:02 AM, Stefano Zampini wrote:
>>         How can I remove a file created by the executable I'm testing
>>         with the new test har
>> <https://maps.google.com/?q=with+the+new+test+har&entry=gmail&source=g>
>> ness?
>>         --         Stefano
>>     --     Tech-X Corporation kruger at txcorp.com <mailto:kruger at txcorp.com
>>     5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
>>     <tel:%28720%29%20974-1841>
>>     Boulder, CO 80303                Fax: (303) 448-7756
>>     <tel:%28303%29%20448-7756>
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171129/60ed2649/attachment.html>
