[petsc-dev] remove temporary output with new test-harness
Scott Kruger
kruger at txcorp.com
Wed Nov 29 11:23:47 CST 2017
The generated scripts automatically run in a subdirectory to avoid name
conflicts. For example, runex1.sh creates a runex1 directory relative
to its location and then runs the actual test in there. These temporary
directories are not removed automatically by the test harness as it
hasn't been a problem yet.
Scott
On 11/29/17 9:43 AM, Matthew Knepley wrote:
> On Wed, Nov 29, 2017 at 10:38 AM, Scott Kruger <kruger at txcorp.com
> <mailto:kruger at txcorp.com>> wrote:
> rm $PETSC_ARCH/tests/<path_to_file>/<file>
> I assume you really mean something else, specifically related to the
> generated test script, but there isn't enough information to answer
> that.
> Or more specifically, the test language was not written to generate
> scripts that have an `rm` command in them, so perhaps explaining why
> an extension would be a good idea.]
> I think what Stefano means is the following;
> I write a test for the HDF5 Viewer. It creates a file called
> "vector.dat". I want it removed at the end of the test.
> I think the answer is, the test directory is blown away, so as long as
> the file is in that temp dir, you are fine.
> Thanks,
> Matt
> Scott
> On 11/29/17 6:02 AM, Stefano Zampini wrote:
> How can I remove a file created by the executable I'm testing
> with the new test harness?
> Stefano
> Tech-X Corporation kruger at txcorp.com <mailto:kruger at txcorp.com>
> 5621 Arapahoe Ave, Suite A Phone: (720) 974-1841
> <tel:%28720%29%20974-1841>
> Boulder, CO 80303 Fax: (303) 448-7756
> <tel:%28303%29%20448-7756>
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
