[petsc-dev] Copy scatter and change block size
Stefano Zampini
stefano.zampini at gmail.com
Sat Nov 25 12:49:46 CST 2017
Pierre,
If you have access to the indices used to create the "unblocked" vecscatter, you can then call ISCreateBlock and obtain the vecscatter you want.
To obtain the garray, MatMPIAIJGetSeqAIJ
> On Nov 25, 2017, at 9:26 PM, Pierre Jolivet <pierre.jolivet at enseeiht.fr> wrote:
> OK, so I guess I need to tinker around with VecScatterCreate.
> As a follow-up question, is there an easy way to get the “garray” from http://www.mcs.anl.gov/petsc/petsc-current/src/mat/impls/aij/mpi/mmaij.c.html#line105 <http://www.mcs.anl.gov/petsc/petsc-current/src/mat/impls/aij/mpi/mmaij.c.html#line105> to create the IS I need to feed to VecScatterCreate (after resizing by multiplying its size by bs and by shifting/inserting the proper indices)?
> Basically, I want to create the VecScatter for doing MatMult with a MATSHELL similar to a MATMPIBAIJ, and I want to re-use the information generated by the MatSetUpMultiply_MPIAIJ from a previously set up MATMPIAIJ with the same sparsity pattern.
> Thanks,
> Pierre
>> On 25 Nov 2017, at 4:43 PM, Smith, Barry F. <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>> wrote:
>> Pierre,
>> There is not. The block size is baked directly into the scatter data structure so not trivial to change in a copy.
>> Barry
>>> On Nov 25, 2017, at 7:41 AM, Pierre Jolivet <pierre.jolivet at enseeiht.fr <mailto:pierre.jolivet at enseeiht.fr>> wrote:
>>> Hello,
>>> Given a VecScatter inctx that operates on vectors x and y, I’d like to create a VecScatter inctx_bs with the same pattern, but that operators on vectors x_bs and y_bs with different block sizes than the original x and y (and that are thus of sizes n * bs).
>>> Is there an easy way to do this (I’m a VecScatter noob, sorry in advance if this is trivial)?
>>> Thank you,
>>> Pierre
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171125/610ab48b/attachment.html>
