[petsc-dev] Copy scatter and change block size
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Sat Nov 25 09:43:41 CST 2017
  Pierre,
    There is not. The block size is baked directly into the scatter data structure so not trivial to change in a copy.
  Barry
> On Nov 25, 2017, at 7:41 AM, Pierre Jolivet <pierre.jolivet at enseeiht.fr> wrote:
> Hello,
> Given a VecScatter inctx that operates on vectors x and y, I’d like to create a VecScatter inctx_bs with the same pattern, but that operators on vectors x_bs and y_bs with different block sizes than the original x and y (and that are thus of sizes n * bs).
> Is there an easy way to do this (I’m a VecScatter noob, sorry in advance if this is trivial)?
> Thank you,
> Pierre
