[petsc-dev] nightlybuilds (next vs next-tmp)
Jed Brown
jed at jedbrown.org
Thu Nov 16 23:12:08 CST 2017
Scott Kruger <kruger at txcorp.com> writes:
> I usually do this:
> make -f gmakefile print-test globsearch='dm*'
> Then, when the tests printed out match the search I want, I edit the
> command line to change print-test to test.
You can also tab-complete whatever specific test you want to run. If
you want to run several with the same leading prefix, Meta-Shift-* in
bash will complete everything that the tab completion would have
offered.
