[petsc-dev] nightlybuilds (next vs next-tmp)
Jed Brown
jed at jedbrown.org
Thu Nov 16 13:14:55 CST 2017
Satish Balay <balay at mcs.anl.gov> writes:
> On Wed, 15 Nov 2017, Satish Balay wrote:
>> I'm switching the nightlybuild to next-tmp with the following branches for tonight.
>> $ git fetch -p && comm -12 <(git branch -r --merged origin/next-tmp | sort) <(git branch -r --no-merged origin/master | sort) |grep -v ' origin/next-tmp'
>> origin/barry/remove-petscdatatype-dmgetworkarray
>> origin/barry/snes-view-display-fd
> Merged the above to master.
>> origin/jed/fix-matcreatempibaij/maint
> Jed, I attempted to merge to maint - and I get:
> $ git merge origin/jed/fix-matcreatempibaij/maint
> Auto-merging src/mat/impls/baij/mpi/mpibaij.c
> warning: inexact rename detection was skipped due to too many files.
> warning: you may want to set your merge.renamelimit variable to at least 2601 and retry the command.
> Merge made by the 'recursive' strategy.
> src/mat/impls/baij/mpi/mpibaij.c | 4 +++-
> 1 file changed, 3 insertions(+), 1 deletion(-)
> Don't know why - can you take care of this merge?
Done.
