[petsc-dev] nightlybuilds (next vs next-tmp)
Richard Tran Mills rtmills at anl.gov
Wed Nov 15 19:56:26 CST 2017
On Sun, Nov 12, 2017 at 9:54 AM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > On Nov 12, 2017, at 11:21 AM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Sun, Nov 12, 2017 at 12:17 PM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> > On Sun, 12 Nov 2017, Matthew Knepley wrote:
> > > Have we tried histogramming test times? It would be nice to know how
> much
> > > cumulative
> > > time it takes to run 37%, 67%, 95%, etc.
> > I'm not sure what 'histogramming test time' means.
> > The below looked like cumulative times over all tests. I want the time
> for each test, and then
> > we bin them into say 10s wide bins and see which ones are taking the
> most time.
>   WE FREAKING NEED TO CONVERT TO THE NEW TEST HARNESS TO DO THIS, then it
> is easy.
>   So everyone, please, instead of spending twenty minutes a day sending
> and reading email about testing spend 20 minutes a day converting examples
> from the old tests to the new harness!!!!!
For those of us who have no idea how to do this, could someone please give
me a pointer or two on where to look for an example or two or some
documentation? I should probably be spending a few minutes a day converting
some examples, but I don't know how or where to start.
--Richard
> >    Matt
> > All logs record time. And Karl's script summarizes those times on the
> > dashboard. For eg:
> > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/
> 11/11/maint.html
> > If you want to do some analysis on those times - you can grab the
> > [historical] logs and run the required analysis.
> > Satish
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171115/5fbcd4f2/attachment.html>
