[petsc-dev] proposed minor PetscPartitioner changes
Matthew Knepley
knepley at gmail.com
Sat Nov 11 12:14:36 CST 2017
On Sat, Nov 11, 2017 at 1:12 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> >> Matrix and graph are equivalent concepts.
> > This is clearly wrong. A matrix is the coordinate representation of a
> > linear operator, and thus has a specific
> > behavior under coordinate transformations. A graph is just connectivity,
> > and really just a relation. I cannot
> > count the number of times Barry has ranted about this on petsc-maint
> > (usually about Vecs and arrays). The
> > mathematical object is not its data structure.
> A graph Laplacian certainly does transform under coordinate
> transformation and indeed, we use that property to design effective
> coarsening strategies. That one basis strikes you as intrinsically
> "more canonical" does not mean it isn't a linear operator.
That is one operator. This is argument by anecdote. An arbitrary graph is
not
a linear operator, but an arbitrary matrix definitely is (the coordinate
representation of one).
Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171111/cf1c4918/attachment.html>
