[petsc-dev] proposed minor PetscPartitioner changes
Vaclav Hapla
vaclav.hapla at erdw.ethz.ch
Thu Nov 9 04:53:26 CST 2017
Thanks for the discussion. I think we got further.
> 8. 11. 2017 v 20:42, Matthew Knepley <knepley at gmail.com>:
> On Wed, Nov 8, 2017 at 2:27 PM, Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> wrote:
> Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> writes:
> > On Wed, Nov 8, 2017 at 1:49 PM, Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> wrote:
> >> >> > No, this is the right structure.
> >> >> Oh come on. You're defending a quadratic algorithm.
> >> >> ierr = ParMETIS_V3_PartKway(vtxdist, xadj, adjncy, vwgt, adjwgt,
> >> >> &wgtflag, &numflag, &ncon, &nparts, tpwgts, ubvec, options, &edgeCut,
> >> >> assignment, &comm);
> >> >> for (p = 0, i = 0; p < nparts; ++p) {
> >> >> for (v = 0; v < nvtxs; ++v) {
> >> >> if (assignment[v] == p) points[i++] = v;
> >> >> MatPartitioningApply creates an IS with "assignment" and can be
> >> >> converted to a global numbering with ISPartitioningToNumbering. You
> >> >> could as well have an ISPartitioningToSectionAndIS() that produces your
> >> >> representation, preferably without this silly quadratic algorithm.
> >> > Time it. Tell me if it matters. Telling me it matters in the long run is
> >> > metaphysics.
Jed replied exactly what I needed to know - whether there's some easy conversion from the natural IS output of MatPartitioningApply into IS+PetscSection DMPlexDistribute needs. He showed there actually is a way, and it won't have worse performance (theoretical performance benefit). Moreover, what you do now for every PetscPartitioner implementation (all those "Convert to PetscSection+IS" blocks) would be done just in one place (design benefit). In this context, the request for timing was slightly unfair, I think.
> >> I realize ParMETIS isn't scalable and that if you have a modest number
> >> of parts and only a million or so elements per rank, the cost of what
> >> you do here will be acceptable for most uses.
> >> But you didn't refute my point that ISPartitioningToSectionAndIS can
> >> produce the representation you want.
> > I do not think its an either or thing. Many equivalent interfaces are
> > possible,
> > so I should have told Vaclav "I think this is the right one", but I thought
> > that
> > was implicit in me being the responder, and none of us thinking that there
> > is
> > a true "right" in interface design.
> >> The IS you're creating is similar
> >> to the inverse of the Numbering (which is a permutation). You are the
> >> one that replaced a scalable algorithm that has existed for a long time
> >> and uses types correctly with PetscPartitioner which has some ugly
> >> warts, duplicates a lot of code, and isn't a viable replacement for
> >> MatPartitioning.
> > 1) MatPartitioning is not a replacement for what I do. According to you,
> > that
> > should end the argument right there.
> > 2) Deep inside MatPartitioning, it must split things up as I do in order to
> > pack
> > stuff to be sent. I think it should be exposed as I have done.
> Pack what stuff to be sent? PetscPartitionerPartition() takes the
> arguments to ParMETIS directly as arrays. To use MatPartitioning, you
> pass those same arrays to MatCreateMPIAdj which literally just holds the
> pointers. Then MatPartitioningApply passes those on to ParMETIS or
> whichever partitioning package. PetscPartitionerPartition_*
> implementations depends on DM strictly as a way to define the weights.
> That isn't more general or better; it's more restrictive.
> This sounds like deliberate misunderstanding. We are not talking about the input to
> ParMetis, but the output. The biggest shortcoming of ParMetis (and indeed all mesh
> partitioners) is that they tell you what must move, but do not move it. This is the value
> add of Plex, it moves the mesh (including all connectivity) and the field data according
> to the partition. In order to do this communication, you always want the partition segmented
> by rank, as it is in the Section/IS output.
I think we are talking here about both input and output!
What PetscPartitionerPartition actually does is getting the adjacency information from the DM using
DMPlexCreatePartitionerGraph(DM dm, PetscInt height, PetscInt *numVertices, PetscInt **offsets, PetscInt **adjacency, IS *globalNumbering)
and these raw arrays are then passed to
(*part->ops->partition)(part, dm, size, numVertices, start, adjacency, partSection, partition);
This I don't like from couple of reasons:
1) the type-specific function has completely different arguments than the interface function - this is slightly non-standard, and if you talk about exposing, there should be an interface function with these arguments
2) on the other hand you derive IS+PetscSection output from the "raw" partitioner output inside each PetscPartitionerPartition_* separately ("Convert to PetscSection+IS" blocks)
3) so part->ops->partition mixes "raw" inputs and "derived" outputs which sounds messy
I fully agree with Jed (and it seems it's compatible with Barry and Lisandro) this should be doable in a clearer way using MatCreateMPIAdj, MatPartitioningSetAdjacency, MatPartitioningApply, ISPartitioningToSectionAndIS (the latter to be done).
> I see no reason why PetscPartitioner cannot be implemented as a very
> small amount of code around MatPartitioning (little more than the
> interface function). The opposite would necessarily bring in concepts
> like DM that are unnecessary when a user is partitioning matrices and
> graphs.
> I am not arguing that it should not be done. I am saying
> - I do not want to do it, because the payoff is small
> - I do not want it to break anything that currently works
> - I do not want it to break the interface we currently have to PetscPartitioner because I think it is genuinely good
I think the payoff isn't necessarily small. Just imagine how much code could be avoided for further maintenance, or if there would be some new partitioner we wanted to interface. And I think the code much clearer to anyone who wants to learn how it works or even improve something.
I'm not that afraid about breaking. Grep tells me there's exactly one call to PetscPartitionerPartition in whole PETSc - in DMPlexDistribute.
One thing I always liked on PETSc is a culture of not sticking to status quo!
> > 3) I think you exaggerate the faults of the code for effect. Do what you
> > must.
> >> And now you seem to be arguing against Vaclav unifying
> >> it, claiming technical rationale that don't appear to hold up.
> > Of course, I disagree with you, and think you make no attempt to understand
> > why
> > someone would write this code, because you never solve the problems its
> > necessary
> > for.
I understand you spent the most time with DMPlex, and it's a masterpiece! But it can always be beneficial to take into account a fresh view of someone who was not involved before.
I think I need to create a proof-of-concept. I would start by employing MatPartitioning in PetscPartitionerPartition with anything outside of this function untouched for now (as already suggested in #192), if you agree.
Or what about implementing a special temporary PetscPartitioner implementation wrapping MatPartitioning?
PETSCPARTITIONERMATPARTITIONING sounds crazy, though :) But could be a good starting point.
Thanks
Vaclav
> I have written a parallel unstructured FEM that did this sort of
> partitioning and redistribution on the fly. I wrote it in terms of
> MatPartitioning and it worked fine. I abandoned it because it had
> screwy dependencies and you had abandoned Sieve to work on
> DMComplex/DMPlex. I'm happy to have made that change, but the concepts
> and requirements are hardly foreign to me.
> Worked fine for you :) It always different with other people.
> >> I don't
> >> understand why, but it certainly looks like PetscPartitioner can be
> >> implemented as a thin layer around MatPartitioning, then that layer can
> >> be refactored into helper functions at the IS/PetscSection level.
> > It might be true. To me, it looked like Mat stuff was draped on so it would
> > be hard
> > to pull the raw result out of the partitioner, and that things would get
> > created (like
> > the MatMult Scatter) which I did not want.
> Barry created the MPIADJ representations in 1997 precisely for this purpose.
> Fair.
> Matt
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171109/43ce9c47/attachment-0001.html>
