[petsc-dev] proposed minor PetscPartitioner changes
Vaclav Hapla
vaclav.hapla at erdw.ethz.ch
Mon Nov 6 07:09:32 CST 2017
Hello
The whole PetscPartitioner class sources are part of src/dm/impls/plex/plexpartition.c, mixed together with some DMPlex* functions.
If you don't mind, I would move the PetscPartitioner* stuff into the separate file petscpartitioner.c
(in future, it could be even moved to a separate directory).
I would also like to
* add PetscPartitioner{Add,Set,Get}OptionsPrefix,
* create the partitioner lazily in DMPlexGetPartitioner, followed by PetscObjectIncrementTabLevel, PetscLogObjectParent and PetscPartitionerSetOptionsPrefix calls,
* edit src/dm/impls/plex/examples/tutorials/ex5.c so that it calls DMSetFromOptions right after DMPlexCreateFromFile, in order to make the partitioner changeable from options.
Do you have anything against?
Vaclav
