[petsc-dev] Recover from TS failure
Mark Adams mfadams at lbl.gov
Wed Nov 1 19:11:24 CDT 2017
> The last relevant output you've shown me is SNES failing a bunch of
> times as the adaptive controller attempts to shrink the step size and
> retry.  If you fixed that problem, you need to tell me.  If not, THAT is
> the problem you need to fix.
That is the problem I am trying to fix. Note, I am also adapting the time
step when the solver converges but talks a lot of iterations. Thus, no need
for recovery.
It is the SNES failure, recover, cut time step, try again, that I am
working in now.
> Did you read about -ts_error_if_step_fails on the man page
Google, and found the command line args
> for the
> functional interface I just cited?
Sorry, I missed this cite and used 'git grep' to see that it was there
(Matt sent me the SNES version today so I knew what to look for).
> >> but all the logic you're talking about is already in TS and
> >> jury-rigging it on the outside is counterproductive.  So get back to
> >> the root of the problem and debug why SNES is failing.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171101/df6a1d2f/attachment.html>
