[petsc-dev] Recover from TS failure
    Mark Adams
    mfadams at lbl.gov
    Wed Nov  1 13:45:22 CDT 2017
On Wed, Nov 1, 2017 at 2:34 PM, Jed Brown <jed at jedbrown.org> wrote:
> Mark Adams <mfadams at lbl.gov> writes:
> > Oh, Maybe the Jacobian has Nans or Infs even though the last time step
> > survived. Maybe it was going crazy. I'll check
> If that is the case you would use TSSetFunctionDomainError().
Ah, very cool. Good to know. That does not seem to be the problem. Not sure
what would cause this linear solver error. I'll try different solvers and
see if I get any hints,
Thanks again,
> > On Wed, Nov 1, 2017 at 2:13 PM, Mark Adams <mfadams at lbl.gov> wrote:
> >> Yea, I don't understand the linear solve error:
> >> -ts_monitor -ts_type beuler -pc_type lu -pc_factor_mat_solver_package
> >> mumps -ksp_type preonly -snes_monitor -snes_rtol 1.e-10 -snes_stol
> 1.e-10
> >> -snes_converged_reason -snes_atol 1.e-18 -snes_converged_reason
> >> Maybe mumps?
> >>> > On Wed, Nov 1, 2017 at 1:46 PM, Jed Brown <jed at jedbrown.org> wrote:
> >>> >> > I have added some code in a TS post step method to look at the
> >>> number of
> >>> >> > nonlinear iterations and cut the time step if it took too many
> SNES
> >>> >> > iterations.  That helped but now I want to go one step further and
> >>> >> recover
> >>> >> > from a failed time step (see appended error message).
> >>> >> > How can/should I recover from a SNES failure inside of TS? I could
> >>> just
> >>> >> put
> >>> >> > TSSolve in a loop and if TS failed because of the solver, then
> >>> reduce the
> >>> >> > time step and try to recover the state, and try again.
> >>> >> > Thoughts?
> >>> >> > Thanks,
> >>> >> > Mark
> >>> >> > Note, this is a direct solver and the linear solver is diverging?
> >>> I've
> >>> >> > seen the same thing with the maximum its in SNES and failed
> >>> linesearch.
> >>> >> > 23 TS dt 0.0025 time 0.1025
> >>> >> >     0 SNES Function norm 9.997473571601e+04
> >>> >> >     1 SNES Function norm 2.295851692533e-01
> >>> >> >   Nonlinear solve did not converge due to DIVERGED_LINEAR_SOLVE
> >>> >> iterations 1
> >>> >> > [0]PETSC ERROR: --------------------- Error Message
> >>> >> > [0]PETSC ERROR:
> >>> >> > [0]PETSC ERROR: TSStep has failed due to DIVERGED_NONLINEAR_SOLVE,
> >>> >> increase
> >>> >> > -ts_max_snes_failures or make negative to attempt recovery
> >>> >> Did you increase -ts_max_snes_failures (TSSetMaxSNESFailures)?
> >>> > Ah, read the error message :) with a negative value I get this.
> >>> > TS can not, or is not going to try, to reconstruct my state and
> reduce
> >>> the
> >>> > time step. So I think I need to do this myself.
> >>> I don't understand.  Why is the linear solve diverging
> >>> (-ksp_converged_reason)?  What TS are you using?
> >>> > I guess just making loop and testing in the TSConvergedReason, is the
> >>> way
> >>> > to go. We already do something like this for mesh adpativity.
> >>> > Thanks,
> >>> iterations 1
> >>> iterations 0
> >>> iterations 0
> >>> iterations 0
> >>> iterations 0
> >>> iterations 0
> >>> iterations 0
> >>> iterations 0
> >>> iterations 0
> >>> iterations 0
> >>> iterations 0
> >>> > [0]PETSC ERROR:
> >>> > [0]PETSC ERROR: TSStep has failed due to DIVERGED_STEP_REJECTED
> >>> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/
> documentation/faq.html
> >>> for
> >>> > trouble shooting.
> >>> > [0]PETSC ERROR: Petsc Development GIT revision: v3.8-53-ga2d93b2d43
> GIT
> >>> > Date: 2017-10-09 12:56:49 -0400
> >>> > [0]PETSC ERROR: ./ex48 on a arch-macosx-gnu-O named MarksMac-5.local
> by
> >>> > markadams Wed Nov  1 13:51:24 2017
> >>> > [0]PETSC ERROR: Configure options --with-cc=clang --with-cc++=clang++
> >>> > COPTFLAGS="-O2 -g -mavx2" CXXOPTFLAGS="-O2 -g -mavx2" FOPTFLAGS="-O2
> -g
> >>> > -mavx2" --download-mpich=1 --download-parmetis=1 --download-metis=1
> >>> > --download-hypre=1 --download-ml=1 --download-triangle=1
> >>> > --download-ctetgen=1 --download-p4est=1 --download-fftw
> >>> --download-mumps=1
> >>> > --download-scalapack=1 --with-x=0 --download-superlu_dist
> >>> > --download-superlu --download-ctetgen --with-debugging=0
> >>> --download-hdf5=1
> >>> > PETSC_ARCH=arch-macosx-gnu-O --download-chaco
> --with-viewfromoptions=1
> >>> > [0]PETSC ERROR: #1 TSStep() line 4130 in
> >>> > /Users/markadams/Codes/petsc/src/ts/interface/ts.c
> >>> > [0]PETSC ERROR: #2 TSSolve() line 4374 in
> >>> > *********** DIVERGED_STEP_REJECTED ierr=91 reason=-2
> >>> > L_2 Diff: 1.32241e+07 at time 0.1025
> >>> >> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/d
> >>> >> for
> >>> >> > trouble shooting.
> v3.8-53-ga2d93b2d43
> >>> GIT
> MarksMac-5.local
> >>> by
> >>> >> > markadams Wed Nov  1 13:17:15 2017
> --with-cc++=clang++
> FOPTFLAGS="-O2
> >>> -g
> --download-metis=1
> >>> >> --download-mumps=1
> >>> >> --download-hdf5=1
> >>> >> > [0]PETSC ERROR: #1 TSStep() line 4129 in
> >>> >> > [0]PETSC ERROR: #3 main() line 1161 in /Users/markadams/Codes/mhd/
> >>> >> src/ex48.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171101/b3d4360b/attachment.html>
