[petsc-dev] Recover from TS failure
Jed Brown jed at jedbrown.org
Wed Nov 1 13:34:36 CDT 2017
Mark Adams <mfadams at lbl.gov> writes:
> Oh, Maybe the Jacobian has Nans or Infs even though the last time step
> survived. Maybe it was going crazy. I'll check
If that is the case you would use TSSetFunctionDomainError().
> On Wed, Nov 1, 2017 at 2:13 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> Yea, I don't understand the linear solve error:
>> -ts_monitor -ts_type beuler -pc_type lu -pc_factor_mat_solver_package
>> mumps -ksp_type preonly -snes_monitor -snes_rtol 1.e-10 -snes_stol 1.e-10
>> -snes_converged_reason -snes_atol 1.e-18 -snes_converged_reason
>> Maybe mumps?
>>> >> > I have added some code in a TS post step method to look at the
>>> number of
>>> >> > nonlinear iterations and cut the time step if it took too many SNES
>>> >> > iterations.  That helped but now I want to go one step further and
>>> >> recover
>>> >> > from a failed time step (see appended error message).
>>> >> > How can/should I recover from a SNES failure inside of TS? I could
>>> just
>>> >> put
>>> >> > TSSolve in a loop and if TS failed because of the solver, then
>>> reduce the
>>> >> > time step and try to recover the state, and try again.
>>> >> > Thoughts?
>>> >> > Thanks,
>>> >> > Mark
>>> >> > Note, this is a direct solver and the linear solver is diverging?
>>> I've
>>> >> > seen the same thing with the maximum its in SNES and failed
>>> linesearch.
>>> >> > 23 TS dt 0.0025 time 0.1025
>>> >> >     0 SNES Function norm 9.997473571601e+04
>>> >> >     1 SNES Function norm 2.295851692533e-01
>>> >> >   Nonlinear solve did not converge due to DIVERGED_LINEAR_SOLVE
>>> >> iterations 1
>>> >> > [0]PETSC ERROR: --------------------- Error Message
>>> >> > [0]PETSC ERROR:
>>> >> > [0]PETSC ERROR: TSStep has failed due to DIVERGED_NONLINEAR_SOLVE,
>>> >> increase
>>> >> > -ts_max_snes_failures or make negative to attempt recovery
>>> >> Did you increase -ts_max_snes_failures (TSSetMaxSNESFailures)?
>>> > Ah, read the error message :) with a negative value I get this.
>>> > TS can not, or is not going to try, to reconstruct my state and reduce
>>> the
>>> > time step. So I think I need to do this myself.
>>> I don't understand.  Why is the linear solve diverging
>>> (-ksp_converged_reason)?  What TS are you using?
>>> > I guess just making loop and testing in the TSConvergedReason, is the
>>> way
>>> > to go. We already do something like this for mesh adpativity.
>>> > Thanks,
>>> iterations 1
>>> iterations 0
>>> iterations 0
>>> iterations 0
>>> iterations 0
>>> iterations 0
>>> iterations 0
>>> iterations 0
>>> iterations 0
>>> iterations 0
>>> iterations 0
>>> > [0]PETSC ERROR:
>>> > [0]PETSC ERROR: TSStep has failed due to DIVERGED_STEP_REJECTED
>>> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>> for
>>> > trouble shooting.
>>> > [0]PETSC ERROR: Petsc Development GIT revision: v3.8-53-ga2d93b2d43  GIT
>>> > Date: 2017-10-09 12:56:49 -0400
>>> > [0]PETSC ERROR: ./ex48 on a arch-macosx-gnu-O named MarksMac-5.local by
>>> > markadams Wed Nov  1 13:51:24 2017
>>> > [0]PETSC ERROR: Configure options --with-cc=clang --with-cc++=clang++
>>> > COPTFLAGS="-O2 -g -mavx2" CXXOPTFLAGS="-O2 -g -mavx2" FOPTFLAGS="-O2 -g
>>> > -mavx2" --download-mpich=1 --download-parmetis=1 --download-metis=1
>>> > --download-hypre=1 --download-ml=1 --download-triangle=1
>>> > --download-ctetgen=1 --download-p4est=1 --download-fftw
>>> --download-mumps=1
>>> > --download-scalapack=1 --with-x=0 --download-superlu_dist
>>> > --download-superlu --download-ctetgen --with-debugging=0
>>> --download-hdf5=1
>>> > PETSC_ARCH=arch-macosx-gnu-O --download-chaco --with-viewfromoptions=1
>>> > [0]PETSC ERROR: #1 TSStep() line 4130 in
>>> > /Users/markadams/Codes/petsc/src/ts/interface/ts.c
>>> > [0]PETSC ERROR: #2 TSSolve() line 4374 in
>>> > *********** DIVERGED_STEP_REJECTED ierr=91 reason=-2
>>> > L_2 Diff: 1.32241e+07 at time 0.1025
>>> >> for
>>> >> > trouble shooting.
>>> GIT
>>> by
>>> >> > markadams Wed Nov  1 13:17:15 2017
>>> -g
>>> >> --download-mumps=1
>>> >> --download-hdf5=1
>>> >> > [0]PETSC ERROR: #1 TSStep() line 4129 in
>>> >> > [0]PETSC ERROR: #3 main() line 1161 in /Users/markadams/Codes/mhd/
>>> >> src/ex48.c
