[petsc-dev] Recover from TS failure
    Mark Adams
    mfadams at lbl.gov
    Wed Nov  1 12:54:53 CDT 2017
On Wed, Nov 1, 2017 at 1:46 PM, Jed Brown <jed at jedbrown.org> wrote:
> Mark Adams <mfadams at lbl.gov> writes:
> > I have added some code in a TS post step method to look at the number of
> > nonlinear iterations and cut the time step if it took too many SNES
> > iterations.  That helped but now I want to go one step further and
> recover
> > from a failed time step (see appended error message).
> > How can/should I recover from a SNES failure inside of TS? I could just
> put
> > TSSolve in a loop and if TS failed because of the solver, then reduce the
> > time step and try to recover the state, and try again.
> > Thoughts?
> > Thanks,
> > Mark
> > Note, this is a direct solver and the linear solver is diverging?  I've
> > seen the same thing with the maximum its in SNES and failed linesearch.
> > 23 TS dt 0.0025 time 0.1025
> >     0 SNES Function norm 9.997473571601e+04
> >     1 SNES Function norm 2.295851692533e-01
> >   Nonlinear solve did not converge due to DIVERGED_LINEAR_SOLVE
> iterations 1
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: TSStep has failed due to DIVERGED_NONLINEAR_SOLVE,
> increase
> > -ts_max_snes_failures or make negative to attempt recovery
> Did you increase -ts_max_snes_failures (TSSetMaxSNESFailures)?
Ah, read the error message :) with a negative value I get this.
TS can not, or is not going to try, to reconstruct my state and reduce the
time step. So I think I need to do this myself.
I guess just making loop and testing in the TSConvergedReason, is the way
to go. We already do something like this for mesh adpativity.
  Nonlinear solve did not converge due to DIVERGED_LINEAR_SOLVE iterations 1
  Nonlinear solve did not converge due to DIVERGED_LINEAR_SOLVE iterations 0
[0]PETSC ERROR:
[0]PETSC ERROR: TSStep has failed due to DIVERGED_STEP_REJECTED
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.8-53-ga2d93b2d43  GIT
Date: 2017-10-09 12:56:49 -0400
[0]PETSC ERROR: ./ex48 on a arch-macosx-gnu-O named MarksMac-5.local by
markadams Wed Nov  1 13:51:24 2017
[0]PETSC ERROR: Configure options --with-cc=clang --with-cc++=clang++
COPTFLAGS="-O2 -g -mavx2" CXXOPTFLAGS="-O2 -g -mavx2" FOPTFLAGS="-O2 -g
-mavx2" --download-mpich=1 --download-parmetis=1 --download-metis=1
--download-hypre=1 --download-ml=1 --download-triangle=1
--download-ctetgen=1 --download-p4est=1 --download-fftw --download-mumps=1
--download-scalapack=1 --with-x=0 --download-superlu_dist
--download-superlu --download-ctetgen --with-debugging=0 --download-hdf5=1
PETSC_ARCH=arch-macosx-gnu-O --download-chaco --with-viewfromoptions=1
[0]PETSC ERROR: #1 TSStep() line 4130 in
/Users/markadams/Codes/petsc/src/ts/interface/ts.c
[0]PETSC ERROR: #2 TSSolve() line 4374 in
*********** DIVERGED_STEP_REJECTED ierr=91 reason=-2
L_2 Diff: 1.32241e+07 at time 0.1025
> for
> > trouble shooting.
> > markadams Wed Nov  1 13:17:15 2017
> --download-mumps=1
> --download-hdf5=1
> > [0]PETSC ERROR: #1 TSStep() line 4129 in
> > [0]PETSC ERROR: #3 main() line 1161 in /Users/markadams/Codes/mhd/
> src/ex48.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171101/628729de/attachment.html>
