[petsc-dev] Recover from TS failure
Jed Brown jed at jedbrown.org
Wed Nov 1 12:46:12 CDT 2017
Mark Adams <mfadams at lbl.gov> writes:
> I have added some code in a TS post step method to look at the number of
> nonlinear iterations and cut the time step if it took too many SNES
> iterations.  That helped but now I want to go one step further and recover
> from a failed time step (see appended error message).
> How can/should I recover from a SNES failure inside of TS? I could just put
> TSSolve in a loop and if TS failed because of the solver, then reduce the
> time step and try to recover the state, and try again.
> Thoughts?
> Thanks,
> Mark
> Note, this is a direct solver and the linear solver is diverging?  I've
> seen the same thing with the maximum its in SNES and failed linesearch.
> 23 TS dt 0.0025 time 0.1025
>     0 SNES Function norm 9.997473571601e+04
>     1 SNES Function norm 2.295851692533e-01
>   Nonlinear solve did not converge due to DIVERGED_LINEAR_SOLVE iterations 1
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR:
> [0]PETSC ERROR: TSStep has failed due to DIVERGED_NONLINEAR_SOLVE, increase
> -ts_max_snes_failures or make negative to attempt recovery
Did you increase -ts_max_snes_failures (TSSetMaxSNESFailures)?
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
> trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.8-53-ga2d93b2d43  GIT
> Date: 2017-10-09 12:56:49 -0400
> [0]PETSC ERROR: ./ex48 on a arch-macosx-gnu-O named MarksMac-5.local by
> markadams Wed Nov  1 13:17:15 2017
> [0]PETSC ERROR: Configure options --with-cc=clang --with-cc++=clang++
> COPTFLAGS="-O2 -g -mavx2" CXXOPTFLAGS="-O2 -g -mavx2" FOPTFLAGS="-O2 -g
> -mavx2" --download-mpich=1 --download-parmetis=1 --download-metis=1
> --download-hypre=1 --download-ml=1 --download-triangle=1
> --download-ctetgen=1 --download-p4est=1 --download-fftw --download-mumps=1
> --download-scalapack=1 --with-x=0 --download-superlu_dist
> --download-superlu --download-ctetgen --with-debugging=0 --download-hdf5=1
> PETSC_ARCH=arch-macosx-gnu-O --download-chaco --with-viewfromoptions=1
> [0]PETSC ERROR: #1 TSStep() line 4129 in
> /Users/markadams/Codes/petsc/src/ts/interface/ts.c
> [0]PETSC ERROR: #2 TSSolve() line 4374 in
> [0]PETSC ERROR: #3 main() line 1161 in /Users/markadams/Codes/mhd/src/ex48.c
