[petsc-dev] error configuring on KNL
    Richard Tran Mills
    rtmills at anl.gov
    Fri Jun 30 17:06:30 CDT 2017
Hmm. I get the same error when adding "--download-hypre=0" to an otherwise
functional configure script for Cori KNL. Hypre's configure doesn't like
something about cross-compiling for KNL. It might be possible to make this
work by building on the compute nodes, though this is, unfortunately, not
officially supported on Cori -- NERSC staff say that builds are not
guaranteed to work on the compute nodes, though I've managed to make it
work sometimes.
--Richard
On Fri, Jun 30, 2017 at 1:36 PM, Mark Adams <mfadams at lbl.gov> wrote:
> And any idea on this error? I'm going to try it on a compute node.
> On Fri, Jun 30, 2017 at 2:44 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> Argh, thanks, that is the/a problem.
>> On Fri, Jun 30, 2017 at 2:16 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> https://www.nersc.gov/users/computational-systems/cori/runni
>>> ng-jobs/running-jobs-on-cori-faq/
>>> Perhaps you need to specify the knl partition to srun?
>>> Satish
>>> On Fri, 30 Jun 2017, Mark Adams wrote:
>>> > I am getting this error when I configure on KNL in with-batch.  It is
>>> not
>>> > clear to me what compile line is being used in here. I've sent a bug
>>> report
>>> > to NERSC. Any ideas?
>>> > Thanks,
>>> > 05:13 nid00444 master= ~/petsc$ srun -n 1
>>> ./conftest-arch-cori-knl-opt-cc
>>> > Please verify that both the operating system and the processor support
>>> > Intel(R) AVX512F, ADX, RDSEED, AVX512ER, AVX512PF and AVX512CD
>>> instructions.
>>> > srun: error: nid00444: task 0: Exited with exit code 1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170630/22b3b579/attachment.html>
