[petsc-dev] error configuring on KNL
    Mark Adams
    mfadams at lbl.gov
    Fri Jun 30 15:36:13 CDT 2017
And any idea on this error? I'm going to try it on a compute node.
On Fri, Jun 30, 2017 at 2:44 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Argh, thanks, that is the/a problem.
> On Fri, Jun 30, 2017 at 2:16 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> https://www.nersc.gov/users/computational-systems/cori/runni
>> ng-jobs/running-jobs-on-cori-faq/
>> Perhaps you need to specify the knl partition to srun?
>> Satish
>> On Fri, 30 Jun 2017, Mark Adams wrote:
>> > I am getting this error when I configure on KNL in with-batch.  It is
>> not
>> > clear to me what compile line is being used in here. I've sent a bug
>> report
>> > to NERSC. Any ideas?
>> > Thanks,
>> > 05:13 nid00444 master= ~/petsc$ srun -n 1 ./conftest-arch-cori-knl-opt-c
>> c
>> > Please verify that both the operating system and the processor support
>> > Intel(R) AVX512F, ADX, RDSEED, AVX512ER, AVX512PF and AVX512CD
>> instructions.
>> > srun: error: nid00444: task 0: Exited with exit code 1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170630/f4be3afa/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170630/f4be3afa/attachment.obj>
