[petsc-dev] snes/ex56 target is gone
    Scott Kruger
    kruger at txcorp.com
    Wed Jun 28 16:21:14 CDT 2017
On 6/28/17 2:50 PM, Jed Brown wrote:
> Scott Kruger <kruger at txcorp.com> writes:
>> On 6/28/17 1:42 PM, Barry Smith wrote:
>>>> On Jun 28, 2017, at 2:39 PM, Scott Kruger <kruger at txcorp.com> wrote:
>>>> On 6/28/17 1:35 PM, Jed Brown wrote:
>>>>> Barry Smith <bsmith at mcs.anl.gov> writes:
>>>>>>      Jed,
>>>>>>       Aside from its name and location this is a very useful thing. Should it be in $PETSC_DIR/lib/petsc/conf/ ? since it cannot stay in $PETSC_DIR for --prefix installs?
>>>>> I guess that's a reasonable location.  The file isn't platform-dependent
>>>>> so it could go elsewhere.
I always thought the standard was:
   "lib is for libraries and share is for datafiles"
rather than
   "lib is for platform-dependent and share is for platform independent".
Actually, the standard itself is confusing as where
to put platform-dependent datafiles.
  In that location, it should acquire a line
>>>>> specifying PETSC_ARCH upon install.  The only issue with the path is
>>>>> that you're actually typing it on the command line, and that would be
>>>>> a starter Makefile for anyone building a larger project.
>>>> I would prefer share as it's not critical to the conf
>>>> and is more user oriented (I think of lib/petsc/conf
>>>> as internal to petsc stuff).
>>>     So $PETSC_DIR/share/petsc/?
>> What would be perfect for me with something like Makefile.example as
>> the name.
> That's fine, but the use is not limited to examples.  If we're calling
> this the example makefile, we should at least add comments saying how to
> build more complicated programs.  (Just listing the target dependencies
> gets you much of the way.  Adding accurate dependencies is slightly more
> work but we ought to recommend a clean way because lots of people make a
> mess of it.)
The example in Makefile.example could refer to
either "compile examples" or "here is an example
makefile that you can use as a starting point".
Scott
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
Boulder, CO 80303                Fax:   (303) 448-7756
