[petsc-dev] petsc rewind of next branch?
Jed Brown
jed at jedbrown.org
Fri Jun 16 10:54:03 CDT 2017
smithc11 <smithc11 at rpi.edu> writes:
> I suppose this email should/could go to a petsc mailing list. If you
> agree, please let me know which one and I'll gladly send it there.
Cc'd petsc-next.
> I was just reading through the petsc developer's guide
> https://bitbucket.org/petsc/petsc/wiki/developer-instructions-git
> and an older presentation of yours
> https://jedbrown.org/files/20141113-Software.pdf
> on git workflows involving a master, next, and topic branches.
> In petsc, is the next branch rewound (reset to point at the head of
> master) periodically (i.e., after a release)?
After a feature release.
> If so, what git commands are used for the rewind? In the gitworkflows
> docs: https://git-scm.com/docs/gitworkflows a 'reset --hard' is used
> followed by an 'announcement'. I'm guessing the announcement tells
> folks who cloned the repo that they should expect a history change in
> next?
Yup. Satish has been doing this lately, but I expect the procedure
looks like
git checkout master
... set release version strings
git commit -am'PETSc 3.8 feature release'
git tag -s
git checkout maint
git merge --ff-only master
git checkout master
... set PETSC_VERSION_RELEASE=0 (a flag meaning that this version is not a release)
git checkout next
git reset --hard master
git push origin maint master +next
Then send an email announcing the release and that 'next' has been
rewound. The easiest thing for users is to run
git branch -D next
in which case any subsequent
git checkout next
will create it anew.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170616/17d614d5/attachment.sig>
