[petsc-dev] higher-order coordiate fields in DMPlex
    Matthew Knepley
    knepley at gmail.com
    Fri Jun  2 20:10:59 CDT 2017
On Fri, Jun 2, 2017 at 7:55 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Fri, Jun 2, 2017 at 5:04 PM, Alberto Paganini <
> > Alberto.Paganini at maths.ox.ac.uk> wrote:
> >> Dear PETSc developers,
> >> I'm Alberto and I'm a user of the finite element library Firedrake,
> >> which relies on DMPlex to import meshes.
> > Great.
> >> In order to use higher-order FEs, it is desirable to import higher-order
> >> meshes.
> > I really do not like that term. Let me try and convince you that it is
> > wrong. The topology of the
> > mesh is unchanged. You are only talking about the order of the
> > representation of the geometry
> > field. Thus, it is not the mesh that is "higher order", but the geometry.
> >> I've been told that DMPlex does not offer this future (at present).
> > Toby just merged this to master, so I think we can say that we have alpha
> > support for this. How
> > does it work? We already have a coordinateDM and coordinates Vec, so you
> > just choose a
> > higher order discretization for the DS inside the coordinateDM. Does that
> > make sense?
> Can it load quadratic geometry from a file (ExodusII or otherwise)?
If someone requests a given file format, we can do it. That's how we always
proceed.
   Matt
That's the interesting part -- the quadratic geometry is rarely
> interesting except in elements that touch the boundary and you can't
> infer the true curved boundary without access to a geometric model (a
> much more cumbersome software stack).
experiments lead.
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170602/bdac5ffe/attachment.html>
