[petsc-dev] higher-order coordiate fields in DMPlex
Jed Brown
jed at jedbrown.org
Fri Jun 2 19:55:38 CDT 2017
Matthew Knepley <knepley at gmail.com> writes:
> On Fri, Jun 2, 2017 at 5:04 PM, Alberto Paganini <
> Alberto.Paganini at maths.ox.ac.uk> wrote:
>> Dear PETSc developers,
>> I'm Alberto and I'm a user of the finite element library Firedrake,
>> which relies on DMPlex to import meshes.
> Great.
>> In order to use higher-order FEs, it is desirable to import higher-order
>> meshes.
> I really do not like that term. Let me try and convince you that it is
> wrong. The topology of the
> mesh is unchanged. You are only talking about the order of the
> representation of the geometry
> field. Thus, it is not the mesh that is "higher order", but the geometry.
>> I've been told that DMPlex does not offer this future (at present).
> Toby just merged this to master, so I think we can say that we have alpha
> support for this. How
> does it work? We already have a coordinateDM and coordinates Vec, so you
> just choose a
> higher order discretization for the DS inside the coordinateDM. Does that
> make sense?
Can it load quadratic geometry from a file (ExodusII or otherwise)?
That's the interesting part -- the quadratic geometry is rarely
interesting except in elements that touch the boundary and you can't
infer the true curved boundary without access to a geometric model (a
much more cumbersome software stack).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170602/cbb3c09e/attachment.sig>
