[petsc-dev] How to generate doc locally ?
Franck Houssen franck.houssen at inria.fr
Tue Jul 18 06:10:36 CDT 2017
OK, before git pull, setting PETSC_DIR, the doc was generated but all links where broken.
After, git pull (6fb98a7c848cdb07c87c9d0173bcc48a73c5a75e), I confirm the doc builds, and I have no more error related to find.
But links are still broken.
For instance, there is no index.html in /petsc/docs/manualpages/Vec/index.html, so when I open docs/index.html, I can not click on the "Vector Operations (Vec)" link.
Anyway, no so blocking.
Franck
----- Mail original -----
> De: "Satish Balay" <balay at mcs.anl.gov>
> À: "petsc-dev" <petsc-dev at mcs.anl.gov>
> Envoyé: Lundi 17 Juillet 2017 21:33:49
> Objet: Re: [petsc-dev] How to generate doc locally ?
> On Mon, 17 Jul 2017, Satish Balay wrote:
> > From the error message - it appears that 'find' is treating the whole
> > string as a single option [instead of multiple options listed
> > there]. Perhaps there are superfluous quotes. I'll check.
> Ok - fix with removing the quotes. I pushed this fix to maint - and merged
> with master/next
> Satish
