[petsc-dev] Can I modify x on SampleShellPCApply callback ?
Franck Houssen
franck.houssen at inria.fr
Sun Jul 16 08:51:18 CDT 2017
I am running debian (gcc-6.4), using petsc-dev synchronized on:
>> git log
commit f9d5775f43f69cbce5a7014a6ce3b24cc0e1214a (HEAD -> master, origin/master, origin/HEAD)
when I run petsc/src/ksp/ksp/examples/tutorials/ex15.c, I get:
>> mpirun -n 2 ./ex15.exe -user_defined_pc
Norm of error 5.90715e-08 iterations 15
OK, so far, so good.
Now, I just modify x in SampleShellPCApply (reset to 0. at the end = doing nothing):
>> git diff
diff --git a/src/ksp/ksp/examples/tutorials/ex15.c b/src/ksp/ksp/examples/tutorials/ex15.c
index badccd93b5..482e5ae6b5 100644
--- a/src/ksp/ksp/examples/tutorials/ex15.c
+++ b/src/ksp/ksp/examples/tutorials/ex15.c
@@ -296,6 +296,7 @@ PetscErrorCode SampleShellPCApply(PC pc,Vec x,Vec y)
ierr = PCShellGetContext(pc,(void**)&shell);CHKERRQ(ierr);
ierr = VecPointwiseMult(y,x,shell->diag);CHKERRQ(ierr);
+ ierr = VecSet(x, 0.);CHKERRQ(ierr);
return 0;
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Object is in wrong state
[0]PETSC ERROR: Vec is locked read only, argument # 1
[1]PETSC ERROR: #1 VecSet() line 547 in /home/fghoussen/Documents/INRIA/petsc/src/vec/vec/interface/rvector.c
[1]PETSC ERROR: #2 SampleShellPCApply() line 299 in /home/fghoussen/Documents/INRIA/petsc/local/../src/ksp/ksp/examples/tutorials/ex15.c
Why is that ? Is there a way to "unlock" x ?
It seems, it's possible to modify y but not x: why ?
>> git diff
index badccd93b5..98ae001319 100644
@@ -294,6 +294,7 @@ PetscErrorCode SampleShellPCApply(PC pc,Vec x,Vec y)
SampleShellPC *shell;
PetscErrorCode ierr;
+ ierr = VecSet(y, 0.);CHKERRQ(ierr);
Does PETSc uses x even after the callback has been called ?
My understanding is that at the end of the callback only y matters: y replaces x that has become no-use (y is the new residu): am I wrong ?
If possible, I would like to reuse x (avoiding to re-create a vector) ? Is there a way to "unlock" x ?
Franck
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170716/2ded3e0c/attachment.html>
