[petsc-dev] PetscDataTypeGetSize fortran binding is gone?
Satish Balay
balay at mcs.anl.gov
Fri Jul 14 16:53:39 CDT 2017
Added - and merged to next.
satish
On Fri, 14 Jul 2017, Blaise A Bourdin wrote:
> Got it. It works.
> While you are at it, would you minding adding the binding for PetscOptionsLeft.
> I am attaching the patch,
> diff --git a/src/sys/objects/ftn-custom/zoptionsf.c b/src/sys/objects/ftn-custom/zoptionsf.c
> index 65d64b1580..9d36bc2d4d 100644
> --- a/src/sys/objects/ftn-custom/zoptionsf.c
> +++ b/src/sys/objects/ftn-custom/zoptionsf.c
> @@ -24,6 +24,7 @@
> #define petscoptionsclear_ PETSCOPTIONSCLEAR
> #define petscoptionsinsertstring_ PETSCOPTIONSINSERTSTRING
> #define petscoptionsview_ PETSCOPTIONSVIEW
> +#define petscoptionsleft_ PETSCOPTIONSLEFT
> #define petscobjectviewfromoptions_ PETSCOBJECTVIEWFROMOPTIONS
> #elif !defined(PETSC_HAVE_FORTRAN_UNDERSCORE)
> #define petscoptionsgetenumprivate_ petscoptionsgetenumprivate
> @@ -42,6 +43,7 @@
> #define petscoptionsclear_ petscoptionsclear
> #define petscoptionsinsertstring_ petscoptionsinsertstring
> #define petscoptionsview_ petscoptionsview
> +#define petscoptionsleft_ petscoptionsleft
> #define petscobjectviewfromoptions_ petscobjectviewfromoptions
> #endif
> @@ -254,6 +256,12 @@ PETSC_EXTERN void PETSC_STDCALL petscoptionsview_(PetscOptions *options,PetscVie
> *ierr = PetscOptionsView(*options,v);
> +PETSC_EXTERN void PETSC_STDCALL petscoptionsleft_(PetscOptions *options,PetscErrorCode *ierr)
> + CHKFORTRANNULLOBJECTDEREFERENCE(options);
> + *ierr = PetscOptionsLeft(*options);
> PETSC_EXTERN void PETSC_STDCALL petscobjectviewfromoptions_(PetscObject *obj,PetscObject *bobj,char* option PETSC_MIXED_LEN(loption),PetscErrorCode *ierr PETSC_END_LEN(loption))
> char *o;
> Blaise
> On Jul 14, 2017, at 3:54 PM, Satish Balay <balay at mcs.anl.gov<mailto:balay at mcs.anl.gov>> wrote:
> include/petscsys.h:PETSC_EXTERN PetscErrorCode PetscDataTypeGetSize(PetscDataType,size_t*);
> Looks like this needs a custom stub due to 'size_t' parameter.
> I've aded the custom interface to balay/add-ftn-PetscDataTypeGetSize. Can you give it a try?
> You would have to use a datatype that matches 'size_t' on the fortran size - i.e PetscSizeT.
> Satish
> Hi,
> It looks like the fortran binding for PetscDataTypeGetSize was removed a while ago. Evidently, auto generated binding won’t work here.
> I’m a bit out of sync with the recent fortran changes, but why are automatically generated binding not working anymore, and what should the proper binding look like?
> Alternatively, is there a new recommended way to query the size of a Petsc type from fortran?
> Blaise
> Department of Mathematics and Center for Computation & Technology
> Louisiana State University, Baton Rouge, LA 70803, USA
> Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
