[petsc-dev] PetscDataTypeGetSize fortran binding is gone?
Blaise A Bourdin
bourdin at lsu.edu
Fri Jul 14 16:47:17 CDT 2017
Got it. It works.
While you are at it, would you minding adding the binding for PetscOptionsLeft.
I am attaching the patch,
diff --git a/src/sys/objects/ftn-custom/zoptionsf.c b/src/sys/objects/ftn-custom/zoptionsf.c
index 65d64b1580..9d36bc2d4d 100644
--- a/src/sys/objects/ftn-custom/zoptionsf.c
+++ b/src/sys/objects/ftn-custom/zoptionsf.c
@@ -24,6 +24,7 @@
#define petscoptionsclear_ PETSCOPTIONSCLEAR
#define petscoptionsinsertstring_ PETSCOPTIONSINSERTSTRING
#define petscoptionsview_ PETSCOPTIONSVIEW
+#define petscoptionsleft_ PETSCOPTIONSLEFT
#define petscobjectviewfromoptions_ PETSCOBJECTVIEWFROMOPTIONS
#elif !defined(PETSC_HAVE_FORTRAN_UNDERSCORE)
#define petscoptionsgetenumprivate_ petscoptionsgetenumprivate
@@ -42,6 +43,7 @@
#define petscoptionsclear_ petscoptionsclear
#define petscoptionsinsertstring_ petscoptionsinsertstring
#define petscoptionsview_ petscoptionsview
+#define petscoptionsleft_ petscoptionsleft
#define petscobjectviewfromoptions_ petscobjectviewfromoptions
#endif
@@ -254,6 +256,12 @@ PETSC_EXTERN void PETSC_STDCALL petscoptionsview_(PetscOptions *options,PetscVie
*ierr = PetscOptionsView(*options,v);
+PETSC_EXTERN void PETSC_STDCALL petscoptionsleft_(PetscOptions *options,PetscErrorCode *ierr)
+ CHKFORTRANNULLOBJECTDEREFERENCE(options);
+ *ierr = PetscOptionsLeft(*options);
PETSC_EXTERN void PETSC_STDCALL petscobjectviewfromoptions_(PetscObject *obj,PetscObject *bobj,char* option PETSC_MIXED_LEN(loption),PetscErrorCode *ierr PETSC_END_LEN(loption))
char *o;
Blaise
On Jul 14, 2017, at 3:54 PM, Satish Balay <balay at mcs.anl.gov<mailto:balay at mcs.anl.gov>> wrote:
include/petscsys.h:PETSC_EXTERN PetscErrorCode PetscDataTypeGetSize(PetscDataType,size_t*);
Looks like this needs a custom stub due to 'size_t' parameter.
I've aded the custom interface to balay/add-ftn-PetscDataTypeGetSize. Can you give it a try?
You would have to use a datatype that matches 'size_t' on the fortran size - i.e PetscSizeT.
Satish
On Fri, 14 Jul 2017, Blaise A Bourdin wrote:
It looks like the fortran binding for PetscDataTypeGetSize was removed a while ago. Evidently, auto generated binding won’t work here.
I’m a bit out of sync with the recent fortran changes, but why are automatically generated binding not working anymore, and what should the proper binding look like?
Alternatively, is there a new recommended way to query the size of a Petsc type from fortran?
Blaise
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170714/ab5ad47b/attachment.html>
