[petsc-dev] configure failure
Mark Adams
mfadams at lbl.gov
Thu Jul 13 14:36:19 CDT 2017
BTW, I seemed to have gotten a debug build to work yesterday. I have not
idea what I did different but I have tried every permutation of building
the optimized version, without luck.
On Thu, Jul 13, 2017 at 2:31 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Jul 13, 2017, at 1:28 PM, Tobin Isaac <tisaac at gatech.edu> wrote:
> > p4est is a pretty standard autotools project, I'll check if there's any
> better cross-compiling support than what we're using.
> The problem with most cross-compiling support in autotools is it
> assumes it "somehow" knows about all systems you are cross compiling for;
> which won't be true for new systems that didn't exist when the cross
> compiling support was implemented. This is why I don't have much respect
> for auto tools cross compiling support.
> > On July 13, 2017 2:18:51 PM EDT, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >> p4est configure should provide an option to not run compiled code and
> >> instead have needed values passed in as configure arguments.
> >>> On Jul 13, 2017, at 1:07 PM, Matthew Knepley <knepley at gmail.com>
> >> wrote:
> >>> On Thu, Jul 13, 2017 at 12:32 PM, Mark Adams <mfadams at lbl.gov> wrote:
> >>> Are you cross-compiling there?
> >>> configure:4469: checking whether we are cross compiling
> >>> configure:4477: ftn -o conftest -g -O -fp-model fast -qopt-report=5
> >> -qopenmp-simd conftest.f
> >> -Wl,-rpath,/global/homes/m/madams/petsc/arch-cori-knl-opt-intel/lib
> >> -L/global/homes/m/madams/petsc/arch-cori-knl-opt-intel/lib -lflapack
> >> -L/global/homes/m/madams/petsc/arch-cori-knl-opt-intel/lib -lfblas
> >> -L/opt/cray/pe/mpt/7.4.4/gni/sma/lib64
> >> -L/opt/cray/pe/libsci/16.09.1/INTEL/15.0/mic_knl/lib
> >> -L/opt/cray/pe/hdf5-parallel/1.10.0/INTEL/15.0/lib
> >> -L/opt/cray/dmapp/default/lib64
> >> -L/opt/cray/pe/mpt/7.4.4/gni/mpich-intel/16.0/lib
> >> -L/usr/common/software/darshan/3.1.4/lib
> >> -L/opt/cray/rca/2.1.6_g2c60fbf-2.265/lib64
> >> -L/opt/cray/alps/6.3.4-2.21/lib64
> >> -L/opt/cray/xpmem/2.1.1_gf9c9084-2.38/lib64
> >> -L/opt/cray/dmapp/7.1.1-39.37/lib64
> >> -L/opt/cray/pe/pmi/5.0.10-1.0000.11050.0.0.ari/lib64
> >> -L/opt/cray/ugni/6.0.15-2.2/lib64 -L/opt/cray/udreg/2.3.2-7.54/lib64
> >> -L/opt/cray/pe/atp/2.1.0/libApp -L/opt/cray/wlm_detect/1.2.1-3.10/lib64
> >> -L/usr/common/software/h5part/1.6.6/lib
> >> -L/opt/intel/compilers_and_libraries_2017.2.174/linux/
> compiler/lib/intel64
> >> -L/opt/intel/compilers_and_libraries_2017.2.174/linux/mkl/lib/intel64
> compiler/lib/intel64_lin
> >> -L/usr/lib64/gcc/x86_64-suse-linux/4.8 -L/usr/x86_64-suse-linux/lib
> >> -lhdf5hl_fortran_parallel -lhdf5_fortran_parallel >&5
> >>> ifort: remark #10397: optimization reports are generated in *.optrpt
> >> files in the output location
> >>> configure:4481: $? = 0
> >>> configure:4488: ./conftest
> >>> libhugetlbfs [cori10:124117]: WARNING: Hugepage size 2097152
> >> unavailable
> >>> Please verify that both the operating system and the processor
> >> support Intel(R) AVX512F, ADX, RDSEED, AVX512ER, AVX512PF and AVX512CD
> >> instructions.
> >>> Matt
> >>> On Thu, Jul 13, 2017 at 12:21 PM, Matthew Knepley <knepley at gmail.com>
> >> wrote:
> >>> Toby, this is from the p4est configure:
> >>> o---------------------------------------
> >>> | Checking MPI and related programs
> >>> checking whether we are using MPI... yes
> >>> checking whether we are using MPI I/O... yes
> >>> checking whether we are using MPI_Init_thread... yes
> >>> checking for mpiexec... no
> >>> checking for mpirun... no
> >>> configure: F77 set to ftn
> >>> configure: FC set to ftn
> >>> configure: CC set to cc
> >>> configure: CXX set to CC
> >>> checking whether the Fortran 77 compiler works... yes
> >>> checking for Fortran 77 compiler default output file name... a.out
> >>> checking for suffix of executables...
> >>> checking whether we are cross compiling...configure: error: in
> >> `/global/u2/m/madams/petsc/arch-cori-knl-opt-intel/
> externalpackages/git.p4est':
> >>> configure: error: cannot run Fortran 77 compiled programs.
> >>> If you meant to cross compile, use `--host'.
> >>> See `config.log' for more details
> >>> Mark, gets us
> externalpackages/git.p4est/config.log
> >>> Thanks,
> >>> Matt
> >>> On Thu, Jul 13, 2017 at 11:15 AM, Mark Adams <mfadams at lbl.gov> wrote:
> >>> I always get this error on Cori at NERSC, KNL, but I can usually
> >> rerun configure and it runs the second time. Well, I can't seem to get
> >> this to work now.
> >>> Thanks,
> >>> Mark
> >>> What most experimenters take for granted before they begin their
> >> experiments is infinitely more interesting than any results to which
> >> their experiments lead.
> >>> -- Norbert Wiener
> >>> http://www.caam.rice.edu/~mk51/
> >>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170713/4691348a/attachment.html>
