[petsc-dev] Introducing new "test harness" to PETSc
Scott Kruger kruger at txcorp.com
Tue Jan 24 14:56:46 CST 2017
On 1/24/17 11:31 AM, Sean Farley wrote:
> Scott Kruger <kruger at txcorp.com> writes:
>> On 1/23/17 11:23 PM, Tobin Isaac wrote:
>>> How does tab completion work?  I've tried `make -f gmakefile sys<Tab>`
>>> in zsh and bash but got nothing.
>> Good question.   I think this is handled by the bash-completion project
>> which is normally an apt-get install or brew install, but has never
>> worked on my mac for some reason.
> Are you sure your shell is bash >= 4.0? Bash completion ~2.0 or so
> dropped support for bash 3 (which is the default on macs).
Ahhh!  Thanks, Sean.
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
Boulder, CO 80303                Fax:   (303) 448-7756
