[petsc-dev] Introducing new "test harness" to PETSc
    Sean Farley
    sean at farley.io
    Tue Jan 24 12:31:06 CST 2017
Scott Kruger <kruger at txcorp.com> writes:
> On 1/23/17 11:23 PM, Tobin Isaac wrote:
>> How does tab completion work?  I've tried `make -f gmakefile sys<Tab>`
>> in zsh and bash but got nothing.
> Good question.   I think this is handled by the bash-completion project
> which is normally an apt-get install or brew install, but has never
> worked on my mac for some reason.
Are you sure your shell is bash >= 4.0? Bash completion ~2.0 or so
dropped support for bash 3 (which is the default on macs).
