[petsc-dev] Fwd: [Bitbucket] Pipeline for master failed on c3c607c (petsc/petsc)
    Lisandro Dalcin
    dalcinl at gmail.com
    Sun Jan 22 03:09:44 CST 2017
On 21 January 2017 at 20:27, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    It appears the step that failed is just initializing the virtual
> machine, it hasn't gotten anywhere near PETSc? If it fails in this
> situation it should not send me any email, why should I get spammed with
> email about things I can't do anything about? It should only send me email
> if it is an error in the truly "PETSc" part of the process.
Well, Barry, I'm not sure. These kind of VM issues are not frequent. This
way you know there was a problem and your commit was not tested, then you
can click the link and hit "Rerun" to try again. Of course, I agree the
message is suboptimal, maybe it should mention that the build did not pass
the setup.
Lisandro Dalcin
Research Scientist
Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
4700 King Abdullah University of Science and Technology
al-Khawarizmi Bldg (Bldg 1), Office # 0109
Thuwal 23955-6900, Kingdom of Saudi Arabia
http://www.kaust.edu.sa
Office Phone: +966 12 808-0459
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170122/1f80af20/attachment.html>
