[petsc-dev] Fwd: [Bitbucket] Pipeline for master failed on c3c607c	(petsc/petsc)
    Barry Smith
    bsmith at mcs.anl.gov
    Sat Jan 21 11:27:08 CST 2017
> On Jan 20, 2017, at 11:40 PM, Jed Brown <jed at jedbrown.org> wrote:
> "Step exceeded build limit of 150 minutes"
> What do you want it to do?
   It appears the step that failed is just initializing the virtual machine, it hasn't gotten anywhere near PETSc? If it fails in this situation it should not send me any email, why should I get spammed with email about things I can't do anything about? It should only send me email if it is an error in the truly "PETSc" part of the process.
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>  This is not useful, I should report it to Sean
>> https://bitbucket.org/petsc/petsc/addon/pipelines/home#!/results/%7B4515a93e-06a9-4842-b8f5-a461c21175cf%7D <https://bitbucket.org/petsc/petsc/addon/pipelines/home#!/results/{4515a93e-06a9-4842-b8f5-a461c21175cf}>
>>> Begin forwarded message:
>>> From: Bitbucket <notifications-noreply at bitbucket.org>
>>> Subject: [Bitbucket] Pipeline for master failed on c3c607c (petsc/petsc)
>>> Date: January 20, 2017 at 8:07:20 PM CST
>>> To: <bsmith at mcs.anl.gov>
>>> petsc / petsc <https://bitbucket.org/petsc/petsc>
>>> 	Failed		2 hrs 32 min 22 sec
>>> 	master
>>> 	BarryFSmith committed c3c607c
>>> Fixup more F90 interface definitions for users Time: .15 hours Reported-by: Manuel Valera <mvalera at mail.sdsu.edu>
>>> View this pipeline <https://bitbucket.org/petsc/petsc/addon/pipelines/home#!/results/%7B4515a93e-06a9-4842-b8f5-a461c21175cf%7D/from-email>
>>> Configure email notifications <https://bitbucket.org/account/user/BarryFSmith/notifications/>		             <https://bitbucket.org/>
