[petsc-dev] Introducing new "test harness" to PETSc
    Scott Kruger
    kruger at txcorp.com
    Wed Jan 18 14:33:44 CST 2017
On 1/18/17 1:10 PM, Matthew Knepley wrote:
> On Wed, Jan 18, 2017 at 2:05 PM, Scott Kruger <kruger at txcorp.com
> <mailto:kruger at txcorp.com>> wrote:
>         This does not work
>         knepley/fix-configure-pragmatic *+$:/PETSc3/petsc/petsc-dev$ make -f
>         gmakefile test search=plex%ex1_2
>         make -f gmakefile test search=plex%ex1_2
>         # No tests run
>     If you replace test with "echo_test" as a target it will echo all of
>     the targets.  This is useful for debugging.
>     make -f gmakefile echo_test search=plex%
>     and then make sure you see it.
>     Then do an echo_test to see the match.
>     Here is an example with the current version:
>     > make -f gmakefile echo_test search=sys%
>     sys_tests-runex19 sys_tests-runex10 sys_tests-runex11
>     sys_tests-runex12 sys_tests-runex14 sys_tests-runex31
>     sys_tests-runex31_2 sys_tests-runex20_2 sys_tests-runex20_3
>     sys_tutorials-runex9_2 ...
>     > make -f gmakefile echo_test search=sys%ex9_2
> Okay, the problem seems to be that you can only use one % in the pattern
Yes, it's a limit of gmake syntax.  We also have the searchin argument.
In gmakefile itself:
# Tests can be generated by searching
# Percent is a wildcard (only one allowed):
#    make -f gmakefile test search=sys%ex2
# To match internal substrings (matches *ex2*):
#    make -f gmakefile test searchin=ex2
# For args:
#    make -f gmakefile test argsearch=cuda
However, the searchin does not take wildcard.
For what you want: dm%plex%
perhaps this could work:
--- a/gmakefile
+++ b/gmakefile
@@ -323,6 +323,10 @@ $(alltest.d) : ;
  ifdef search
    TESTTARGETS := $(filter $(search),$(alltesttargets))
+  ifdef searchin
+    TESTTARGETS2 := $(foreach v,$(TESTTARGETS),$(if $(findstring
$(searchin),$(v)),$(v)))
+    TESTTARGETS := $(TESTTARGETS2)
+  endif
  else ifdef searchin
Such that:
 > make -f gmakefile echo_test search=sys% searchin=ex2
sys_tests-runex20_2 sys_tests-runex20_3 sys_tests-runex24
sys_tests-runex28 sys_tests-runex25 sys_tests-runex21 sys_tests-runex20
sys_tests-runex23 sys_tests-runex22 sys_tutorials-runex2 sys_tests-runex2
This still isn't as nice as true regex searching, but it probably gets
one a lot of they way there.
It may also be possible to use shell for true regex.
Looking at that now.
Scott
> gmakefile echo_test search=dm%
> make -f gmakefile echo_test search=dm%
> dm_impls_plex_tests-runex1_2 dm_impls_plex_tests-runex1_3
> dm_impls_plex_tests-runex1_0 dm_impls_plex_tests-runex1_1
> dm_impls_plex_tests-runex1_6 dm_impls_plex_tests-runex1_7
> dm_impls_plex_tests-runex1_4 dm_impls_plex_tests-runex1_5
> dm_impls_plex_tests-runex1_8 dm_impls_plex_tests-runex1_9
> dm_impls_plex_tests-runex1_cgns_1 dm_impls_plex_tests-runex1_cgns_0
> dm_impls_plex_tests-runex1_refine_overlap_1
> dm_impls_plex_tests-runex1_refine_overlap_0
> dm_impls_plex_tests-runex1_med_1 dm_impls_plex_tests-runex1_med_0
> dm_impls_plex_tests-runex1_med_3 dm_impls_plex_tests-runex1_med_2
> dm_impls_plex_tests-runex1_gmsh_3 dm_impls_plex_tests-runex1_gmsh_2
> dm_impls_plex_tests-runex1_gmsh_1 dm_impls_plex_tests-runex1_gmsh_0
> dm_impls_plex_tests-runex1_gmsh_6 dm_impls_plex_tests-runex1_gmsh_5
> dm_impls_plex_tests-runex1_gmsh_4 dm_impls_plex_tests-runex1_fluent_2
> dm_impls_plex_tests-runex1_fluent_3 dm_impls_plex_tests-runex1_fluent_0
> dm_impls_plex_tests-runex1_fluent_1
> dm_impls_plex_tests-runex1_part_simple_1
> dm_impls_plex_tests-runex1_part_simple_0
> gmakefile echo_test search=dm%plex%
> make -f gmakefile echo_test search=dm%plex%
> I do not think this is going to be flexible enough.
>    Matt
>             >   3) How do I give extra arguments with the make
>         interface, rather than
>             > test_harness?
>             That is, run some modification of the test and still do the
>         diff, but
>             don't change the reference output?  I have used
>         PETSC_OPTIONS for that.
>               make .... PETSC_OPTIONS=-more_magic
>     I'm not sure I 100% understand what is being asked (perhaps it's my
>     cold medicine), but I think TESTFLAGS does what you want; e.g.,
>     > make -f gmakefile test search=sys%ex9_2 TESTFLAGS="-h"
>             TEST sys_tutorials-runex9_2
>     Usage:
>     arch-osx-xsdk-opt/tests/src/sys/examples/tutorials/runex9_2.sh [options]
>     OPTIONS
>       -a <args> ......... Override default arguments
>       -c <cleanup> ...... Cleanup (remove generated files)
>       -e <args> ......... Add extra arguments to default
>       -h ................ help: print this message
>       -n <integer> ...... Override the number of processors to use
>       -o <output file> .. Override default output file to diff with
>       -t <testname> ..... Override test name
>       -v ................ Verbose: Print commands
>     # No tests run
>             > Once I have all the functionality of my Python stuff,  I will
>             throw it away.
>         What most experimenters take for granted before they begin their
>         experiments is infinitely more interesting than any results to which
>         their experiments lead.
>         -- Norbert Wiener
>     Tech-X Corporation               kruger at txcorp.com
>     5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
>     <tel:%28720%29%20974-1841>
>     Boulder, CO 80303                Fax:   (303) 448-7756
>     <tel:%28303%29%20448-7756>
> -- Norbert Wiener
