[petsc-dev] Introducing new "test harness" to PETSc
Matthew Knepley
knepley at gmail.com
Wed Jan 18 14:11:34 CST 2017
On Wed, Jan 18, 2017 at 2:05 PM, Scott Kruger <kruger at txcorp.com> wrote:
>> This does not work
>> knepley/fix-configure-pragmatic *+$:/PETSc3/petsc/petsc-dev$ make -f
>> gmakefile test search=plex%ex1_2
>> make -f gmakefile test search=plex%ex1_2
>> # No tests run
> If you replace test with "echo_test" as a target it will echo all of the
> targets. This is useful for debugging.
> make -f gmakefile echo_test search=plex%
> and then make sure you see it.
> Then do an echo_test to see the match.
> Here is an example with the current version:
> > make -f gmakefile echo_test search=sys%
> sys_tests-runex19 sys_tests-runex10 sys_tests-runex11 sys_tests-runex12
> sys_tests-runex14 sys_tests-runex31 sys_tests-runex31_2 sys_tests-runex20_2
> sys_tests-runex20_3 sys_tutorials-runex9_2 ...
> > make -f gmakefile echo_test search=sys%ex9_2
>> > 3) How do I give extra arguments with the make interface, rather
>> than
>> > test_harness?
>> That is, run some modification of the test and still do the diff, but
>> don't change the reference output? I have used PETSC_OPTIONS for
>> that.
>> make .... PETSC_OPTIONS=-more_magic
> I'm not sure I 100% understand what is being asked (perhaps it's my cold
> medicine), but I think TESTFLAGS does what you want; e.g.,
> > make -f gmakefile test search=sys%ex9_2 TESTFLAGS="-h"
> TEST sys_tutorials-runex9_2
> Usage: arch-osx-xsdk-opt/tests/src/sys/examples/tutorials/runex9_2.sh
> [options]
> OPTIONS
> -a <args> ......... Override default arguments
> -c <cleanup> ...... Cleanup (remove generated files)
> -e <args> ......... Add extra arguments to default
> -h ................ help: print this message
> -n <integer> ...... Override the number of processors to use
> -o <output file> .. Override default output file to diff with
> -t <testname> ..... Override test name
> -v ................ Verbose: Print commands
> # No tests run
so I would do
make -f gmakefile test search=sys%ex9_2 TESTFLAGS="-e '-da_grid_x 10'"
Matt
>> > Once I have all the functionality of my Python stuff, I will
>> throw it away.
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
> Tech-X Corporation kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A Phone: (720) 974-1841
> Boulder, CO 80303 Fax: (303) 448-7756
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170118/5fb66a87/attachment.html>
