[petsc-dev] Introducing new "test harness" to PETSc
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Jan 17 21:00:25 CST 2017
> On Jan 17, 2017, at 8:54 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
>> Gripes:
>>  1) How do I run an individual test run?
>  make -f gmakefile sys_tutorials-runex5
> (tab completion works) or use a search that matches only that run.
>> I use
>>  make -f gmakefile test searchin=plex
>> to run plex tests, and I think
>>  make -f gmakefile test searchin=plex*ex1
> Due to make syntax, % is the internal string matcher.
>> will work. However, how do I select ex1_2?
>  make -f gmakefile test search=plex%ex1_2
>>  2) How do I replace the output which exists with the output of the
>> current test run?
>> This is amazingly useful after changes.
> I have this script ~/bin/diffupdate:
> #!/bin/sh
> args=
> if [ "$1" = "-u" ]; then
>    args="-u"
>    shift
> fi
> new="$2"
> ref="$1"
> diff $args "$ref" "$new"
> ret=$?
> echo "Updating $new --> $ref"
> mv "$new" "$ref"
> exit $ret
> Then I run
>  make -f gmakefile test search=plex% DIFF=diffupdate
> It prints the diff and replaces the reference file (first argument) with
> the second.
  Unfortunately I don't have online access to your ~/bin/diffupdate.
  This needs to be a feature of the test harness directly.
>>  3) How do I give extra arguments with the make interface, rather than
>> test_harness?
> That is, run some modification of the test and still do the diff, but
> don't change the reference output?  I have used PETSC_OPTIONS for that.
>  make .... PETSC_OPTIONS=-more_magic
>> Once I have all the functionality of my Python stuff,  I will throw it away.
