[petsc-dev] Introducing new "test harness" to PETSc
Jed Brown jed at jedbrown.org
Tue Jan 17 20:54:38 CST 2017
Matthew Knepley <knepley at gmail.com> writes:
> Gripes:
>   1) How do I run an individual test run?
  make -f gmakefile sys_tutorials-runex5
(tab completion works) or use a search that matches only that run.
> I use
>   make -f gmakefile test searchin=plex
> to run plex tests, and I think
>   make -f gmakefile test searchin=plex*ex1
Due to make syntax, % is the internal string matcher.
> will work. However, how do I select ex1_2?
  make -f gmakefile test search=plex%ex1_2
>   2) How do I replace the output which exists with the output of the
> current test run?
> This is amazingly useful after changes.
I have this script ~/bin/diffupdate:
#!/bin/sh
args=
if [ "$1" = "-u" ]; then
    args="-u"
    shift
fi
new="$2"
ref="$1"
diff $args "$ref" "$new"
ret=$?
echo "Updating $new --> $ref"
mv "$new" "$ref"
exit $ret
Then I run
  make -f gmakefile test search=plex% DIFF=diffupdate
It prints the diff and replaces the reference file (first argument) with
the second.
>   3) How do I give extra arguments with the make interface, rather than
> test_harness?
That is, run some modification of the test and still do the diff, but
don't change the reference output?  I have used PETSC_OPTIONS for that.
  make .... PETSC_OPTIONS=-more_magic
> Once I have all the functionality of my Python stuff,  I will throw it away.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170117/e1140273/attachment.sig>
