[petsc-dev] Introducing new "test harness" to PETSc
    Scott Kruger
    kruger at txcorp.com
    Tue Jan 17 17:08:22 CST 2017
Hmmmm.  Tutorials have Concepts: and Descriptions: enabled
for documentation at the file level.  It might be worthwhile
to add these to document individual tests as a best practice.
Scott
On 1/17/17 4:04 PM, Scott Kruger wrote:
> It has to do with the spacing.  Looking at src/sys/examples/test/ex1.c
> This works:
> /*TEST
>    This test does foo
>    test:
>       filter: egrep "(PETSC ERROR)" | egrep "(main|CreateError|Error
> Created)" | cut -f1,2,3,4,5,6 -d" "
> TEST*/
> which I can see by doing this:
> gabrielle 81: ../../../../config/testparse.py -t ex1.c -v 1
> ex1.c
>    runex1
> but this does not:
> /*TEST
>   This test does foo
>    test:
> TEST*/
> I would suggest that using # as a comment delimiter would be the best
> approach to enabling comments.
> Scott
> On 1/17/17 3:53 PM, Matthew Knepley wrote:
>> On Tue, Jan 17, 2017 at 4:31 PM, Satish Balay <balay at mcs.anl.gov
>> <mailto:balay at mcs.anl.gov>> wrote:
>>     On Tue, 17 Jan 2017, Matthew Knepley wrote:
>>     > Also, how do I put comments inside these blocks to tell me what
>> the test is
>>     > about?
>>     Looks like everything other than the define format is ignored..
>> It does not look that way to me:
>> /usr/bin/python ./config/gmakegentest.py
>> --petsc-arch=arch-c-exodus-master
>> Traceback (most recent call last):
>>   File "./config/gmakegentest.py", line 733, in <module>
>>     main(petsc_arch=opts.petsc_arch, output=opts.output,
>> verbose=opts.verbose, single_ex=opts.single_executable)
>>   File "./config/gmakegentest.py", line 718, in main
>> dataDict=pEx.walktree(os.path.join(pEx.petsc_dir,'src'),action="genPetscTests")
>>   File "./config/gmakegentest.py", line 613, in walktree
>>     eval("self."+action+"(root,dirs,files,dataDict)")
>>   File "<string>", line 1, in <module>
>>   File "./config/gmakegentest.py", line 593, in genPetscTests
>>     dataDict[root].update(testparse.parseTestFile(fullex))
>>   File "/PETSc3/petsc/petsc-dev/config/testparse.py", line 175, in
>> parseTestFile
>>     testDict[basename]=parseTests(testString,srcfile)
>>   File "/PETSc3/petsc/petsc-dev/config/testparse.py", line 140, in
>> parseTests
>>     testname,subdict=parseTest(test,srcfile)
>>   File "/PETSc3/petsc/petsc-dev/config/testparse.py", line 102, in
>> parseTest
>>     val=line.split(":")[1].strip()
>> IndexError: list index out of range
>>    Matt
>>     Satish
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
Boulder, CO 80303                Fax:   (303) 448-7756
