[petsc-dev] Introducing new "test harness" to PETSc
Scott Kruger
kruger at txcorp.com
Tue Jan 17 17:04:21 CST 2017
It has to do with the spacing. Looking at src/sys/examples/test/ex1.c
This works:
/*TEST
This test does foo
test:
filter: egrep "(PETSC ERROR)" | egrep "(main|CreateError|Error
Created)" | cut -f1,2,3,4,5,6 -d" "
TEST*/
which I can see by doing this:
gabrielle 81: ../../../../config/testparse.py -t ex1.c -v 1
ex1.c
runex1
but this does not:
/*TEST
This test does foo
test:
TEST*/
I would suggest that using # as a comment delimiter would be the best
approach to enabling comments.
Scott
On 1/17/17 3:53 PM, Matthew Knepley wrote:
> On Tue, Jan 17, 2017 at 4:31 PM, Satish Balay <balay at mcs.anl.gov
> <mailto:balay at mcs.anl.gov>> wrote:
> On Tue, 17 Jan 2017, Matthew Knepley wrote:
> > Also, how do I put comments inside these blocks to tell me what the test is
> > about?
> Looks like everything other than the define format is ignored..
> It does not look that way to me:
> /usr/bin/python ./config/gmakegentest.py --petsc-arch=arch-c-exodus-master
> Traceback (most recent call last):
> File "./config/gmakegentest.py", line 733, in <module>
> main(petsc_arch=opts.petsc_arch, output=opts.output,
> verbose=opts.verbose, single_ex=opts.single_executable)
> File "./config/gmakegentest.py", line 718, in main
> dataDict=pEx.walktree(os.path.join(pEx.petsc_dir,'src'),action="genPetscTests")
> File "./config/gmakegentest.py", line 613, in walktree
> eval("self."+action+"(root,dirs,files,dataDict)")
> File "<string>", line 1, in <module>
> File "./config/gmakegentest.py", line 593, in genPetscTests
> dataDict[root].update(testparse.parseTestFile(fullex))
> File "/PETSc3/petsc/petsc-dev/config/testparse.py", line 175, in
> parseTestFile
> testDict[basename]=parseTests(testString,srcfile)
> File "/PETSc3/petsc/petsc-dev/config/testparse.py", line 140, in
> parseTests
> testname,subdict=parseTest(test,srcfile)
> File "/PETSc3/petsc/petsc-dev/config/testparse.py", line 102, in parseTest
> val=line.split(":")[1].strip()
> IndexError: list index out of range
> Matt
> Satish
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
Tech-X Corporation kruger at txcorp.com
5621 Arapahoe Ave, Suite A Phone: (720) 974-1841
Boulder, CO 80303 Fax: (303) 448-7756
