[petsc-dev] Fwd: no petsc on Edison
    Kong, Fande
    fande.kong at inl.gov
    Thu Jan 12 14:18:15 CST 2017
On Wed, Jan 11, 2017 at 2:20 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Fande,
> Your issue is different (eventhough the error message is the same) -
> and its fixed.
> You should try latest petsc 'maint' and report if you still have
> issues. [rolling back to PETSc-3.7.3 is not the fix]
Hi Satish,
The lastest petsc 'maint' fixed the issue. Thanks.
Fande
> Satish
> On Wed, 11 Jan 2017, Kong, Fande wrote:
> > On Wed, Jan 11, 2017 at 1:55 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > > On Jan 11, 2017, at 2:41 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> > > > We do not run the code with Satish's fixes, instead, we are using
> > > petsc-3.7.3 and there are not such issues. I guess the issues are
> > > introduced recently.
> > >   Ok, then I am confused. Maybe master fixes the problem?
> > Barry, I am sorry for confusing you. Let me rephrase a little.
> > We encountered this issue when we were using PETSc-3.7.4, and we reported
> > the issue in another thread. Then Satish tried to fix the issue by adding
> > more entities to the lookup, but we did not try the Satish's branch with
> > this fix. We are back to use an old release PETSc-3.7.3. PETSc-3.7.3 is
> > working just fine.
> > In PETSc-3.7.3, there is no such a function called
> > PetscTableCreateHashSize. I hence guess the issue was introduced
> recently.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170112/0a4ce18d/attachment.html>
