[petsc-dev] Fwd: no petsc on Edison
    Satish Balay
    balay at mcs.anl.gov
    Wed Jan 11 15:20:21 CST 2017
Fande,
Your issue is different (eventhough the error message is the same) -
and its fixed.
You should try latest petsc 'maint' and report if you still have
issues. [rolling back to PETSc-3.7.3 is not the fix]
Satish
On Wed, 11 Jan 2017, Kong, Fande wrote:
> On Wed, Jan 11, 2017 at 1:55 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > On Jan 11, 2017, at 2:41 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> > > We do not run the code with Satish's fixes, instead, we are using
> > petsc-3.7.3 and there are not such issues. I guess the issues are
> > introduced recently.
> >   Ok, then I am confused. Maybe master fixes the problem?
> Barry, I am sorry for confusing you. Let me rephrase a little.
> We encountered this issue when we were using PETSc-3.7.4, and we reported
> the issue in another thread. Then Satish tried to fix the issue by adding
> more entities to the lookup, but we did not try the Satish's branch with
> this fix. We are back to use an old release PETSc-3.7.3. PETSc-3.7.3 is
> working just fine.
> In PETSc-3.7.3, there is no such a function called
> PetscTableCreateHashSize. I hence guess the issue was introduced recently.
