[petsc-dev] Fwd: [petsc-users] [SOLVED] make test freeze
Jed Brown
jed at jedbrown.org
Fri Jan 6 10:41:33 CST 2017
Matthew Knepley <knepley at gmail.com> writes:
> OpenMPI is broken again.
> We could:
> a) put in a define for OpenMPI and then disable this in C
> b) put in a flag for OpenMPI and then disable this in Python
> c) try to code up a failing (hanging) test in configure
Hanging tests can't be run on batch systems.
Simplest option seems to be to disable when the Open MPI version number
is too old. I don't care whether that test is in C (OMPI_MAJOR_VERSION)
versus Python. I would use C because petscconf.h doesn't get comments
for why something was disabled, but Barry probably prefers to do it in
configure.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170106/2d6b66b8/attachment.sig>
