[petsc-dev] Fwd: [petsc-users] [SOLVED] make test freeze
    Matthew Knepley
    knepley at gmail.com
    Fri Jan  6 10:26:16 CST 2017
OpenMPI is broken again.
We could:
  a) put in a define for OpenMPI and then disable this in C
  b) put in a flag for OpenMPI and then disable this in Python
  c) try to code up a failing (hanging) test in configure
Other suggestions?
   Matt
---------- Forwarded message ----------
From: Patrick Begou <Patrick.Begou at legi.grenoble-inp.fr>
Date: Fri, Jan 6, 2017 at 10:08 AM
Subject: Re: [petsc-users] [SOLVED] make test freeze
To: Matthew Knepley <knepley at gmail.com>
Cc: PETSc <petsc-users at mcs.anl.gov>
Hi Matthew,
Using the debuguer I finaly found the problem. It is related to MPI. In
src/sys/objects/pinit.c line 779, petsc test the availability of
PETSC_HAVE_MPI_INIT_THREAD and this is set to True beccause my OpenMPI
version is compiled with  --enable-mpi-thread-multiple.
However the call to MPI_Init_thread(argc,args,MPI_THREAD_FUNNELED,&provided)
hangs and freeze the application.
Unsetting PETSC_HAVE_MPI_INIT_THREAD in petsc solves the problem.
I remember a HPC seminar on BULLX systems where they give us some
informations about known problems whith the MPI_Init_thread call in
openMPI. May be I should use a more recent version of OpenMPI. This also
explain why I had this problem with previous versions of petsc (same
OpenMPI environment).
None of our codes mixes OpenMP and MPI.... so I never fall in this
situation in production and petsc always behave fine (excepted for make
test).
Is there a way to turn off PETSC_HAVE_MPI_INIT_THREAD at configure time for
Petsc ? I've manualy removed it in the generated petscconf.h file before
compiling Petsc in debug mode but I don't think it is the best way to to
this.....
Thanks for your help in running separatly the test codes.
Patrick
|  Equipe M.O.S.T.         |                                      |
|  Patrick BEGOU           | mailto:Patrick.Begou at grenoble-inp.fr |
|  LEGI                    |                                      |
|  BP 53 X                 | Tel 04 76 82 51 35                   |
|  38041 GRENOBLE CEDEX    | Fax 04 76 82 52 71                   |
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170106/1bf3eca2/attachment.html>
