[petsc-dev] configure error
Barry Smith
bsmith at mcs.anl.gov
Tue Jan 3 23:03:03 CST 2017
I have attempted to fix this for BlasLapack and its download variants with the branch
barry/update-blaslapack-support-download-batch now in next
> On Dec 29, 2016, at 11:03 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> I don't understand the batch code. I suspect the change from building
> packages from pre-reconfigure to reconfigure happened in
> package.py. However blaslapack doesn't use package.py?
> And blaslapack.py appears to do checksdotreturnsdouble() test - which
> it needs to do during batch test - so it would have to do the install
> before batch test [and not during reconfigure?]
> Sure - it shouldn't chug along...
> Satish
> On Thu, 29 Dec 2016, Barry Smith wrote:
>>> On Dec 29, 2016, at 10:03 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> I suspect blaslpack along with mpi cannot be installed in batch mode anymore.
>> This is nuts! It should be able to build blaslapack. And it certainly shouldn't just chug along without a big error message instead of pretending the option was not set.
>> Presumably batchBodies is only set before the reconfigure?
>> So here it skips the download before, that is ok,
>> def checkDownload(self):
>> '''Check if we should download the package, returning the install directory or the empty string indicating installation'''
>> if not self.download:
>> return ''
>> if self.framework.batchBodies:
>> return
>> Here it skips configure, and if this is only the first time it is ok
>> def configure(self):
>> if self.download and self.argDB['download-'+self.downloadname.lower()] and not self.framework.batchBodies:
>> self.argDB['with-'+self.package] = 1
>> These are the only two mentions of batch in package.py so maybe batchBodies is always set? Then we need a different way
>> to know if it is before or after the reconfigure.
>> Barry
>>> [at some point all pacakges were installed before reconfigure. And I think this was
>>> switched to - install packages during reconfigure. Ideally there should be proper
>>> dependencies on the 'batch' part - so that only packages that require info from the
>>> batch run should get installed during reconfigure stage..]
>>> BTW: Why use --download-fblaslapack on cray? [and not system blas - like cray-libsci]
>>> Satish
>>> On Thu, 29 Dec 2016, Mark Adams wrote:
>>>> --with-batch=0 seems to fix the problem.
>>>> On Thu, Dec 29, 2016 at 4:40 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>> BTW, I cloned this (working) config file and changed to single precision
>>>>> and 32 bit ints, and added with-batch=1.
>>>>> On Wed, Dec 28, 2016 at 11:20 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>>>> I can reproduce this issue. [we don't notice it normally because
>>>>>> default system blas is usually found - so there is no error..]
>>>>>> Satish
>>>>>> On Wed, 28 Dec 2016, Barry Smith wrote:
>>>>>>> Mark,
>>>>>>> Yes this is odd. You clearly have --download-fblaslapack=1 but then
>>>>>> in the file it has
>>>>>>> TEST alternateConfigureLibrary from config.packages.fblaslapack(/g
>>>>>> lobal/u2/m/madams/petsc/config/BuildSystem/config/package.py:761)
>>>>>>> TESTING: alternateConfigureLibrary from config.packages.fblaslapack(co
>>>>>>> Called if --with-packagename=0; does nothing by default
>>>>>>> I suggest try removing all options except the
>>>>>> --download-fblaslapack=1 and the compiler names and the --with-batch and
>>>>>> see if it goes through. Do not cut and past but type each argument; it
>>>>>> could be some strange character being pass in you cannot see.
>>>>>>> Barry
>>>>>>>> On Dec 28, 2016, at 9:52 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>> I am getting an error about blas-lapack, suggesting that I download
>>>>>> it, but I seem to be asking to download it. Not sure what the problem is ...
>>>>>>>> <configure.log>
